Results 1 to 8 of 8
    luv2golf's Avatar
    luv2golf Guest
    Lead in refrigerant
    supposedly a testing company has found lead in the refrigerant (low temp). The mechanicals were all experienced so I don't believe they used lead solder. Anyone have an idea where the lead might come from?
    Aug 2005
    5,302
    Re: Lead in refrigerant
    You did not really give us much information to use. What type of:
    1. compressors do you have?
    2. piping material is used?
    3. refrigerant is it?
    Is this the first time you have noticed lead, or is this the first time you have checked?
    and,
    What were you testing? The oil perhaps?
    11,025
    Also, the use of the word "Supposedly".
    Did they or didn't they ?
    luv2golf's Avatar
    luv2golf Guest
    Sorry,
    Copeland Discuss
    R-22 (new when put in, not reclaim)
    Copper pipe
    5 ppm lead (not much but still, where did it come from)
    Moisture was at 77 ppm with white sludge.
    sounds like a serviceman breached the system
    Been operating for 1 1/2 yrs. Warr out after 12 months, different company servicing.
    thanks
    Aug 2005
    5,302
    If soft solder was not used, then what you may be seeing is residue material from compressor bearings.
    Somerset
    69
    4,698
    Luv2golf
    As Iceman indicates it could well be from your "white metal" Bearings as these are generally an alloy of Lead and Tin.
    So especially as you state this Compressor has worn out after 12 months.
    Due in part to huge Copperisation no doubt?
    Based on the moisture content you quote.
    Jan 2009
    79
    I've come across the white metal from worn bearings a lot-you'll find the sump oil strainer blocked with this stuff if it's bad enough. Better find out why it's wearing bearings so quickly if it's a relatively new compresser.
    A lot of the stores here have 20+ year old stuff.
    This
    Jul 2006
    74
    865
    26
    Missed this thread when it first came out.
    I had a oil analysis done on a Frick Screw years ago and it came back with some strange things in it. The Frick Factor could not explain it. Then one day it dawned on me-Anti-Seize. Lots of stuff can be in that can.
  1. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  2. Leak Testing?
    By Thana in forum Trouble Shooting
    Last Post: 31-08-2010, 02:57 PM
  3. CARE refigerants by BOC
    By dogma in forum Refrigerants
    Last Post: 23-03-2010, 12:39 PM
  4. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
  5. Refrigerant Reclamation
    By herefishy in forum Commercial
    Last Post: 23-07-2003, 08:19 AM
