Results 1 to 8 of 8
17-06-2008, 02:52 PM #1
temporary leak fix ? / adding refrigerant.
Sorry if this is posted in the wrong section. It seemed to be the best fit.
I have a commercial coldplate freezer which has a couple of small leaks according to the company that just serviced it. The leaks are located in the very small refrigeration compartment and they said they cant get to the leak because its in the very back of the compartment. The leak or leak are small and refrigerant needs to be added about every 6-8 weeks. I cant afford the the $1500-2500 repair right now. Ive heard you can use cold weather epoxy on the joints / leak area as a temp fix. Is this true ? I am EPA certified but havent worked for a company in almost 8 years so most of what I knew then has left me.
Also: I have r414b to add to the system when it gets to low. The tech said to add it in liquid form and just crack open the valve and add very slowly. Does that sound right?
17-06-2008, 03:40 PM #2
Re: temporary leak fix ? / adding refrigerant.
R414B A blend of R-22, R-124 and R-142b with hydrocarbon R-600a .
Its also called "Hot shot"
A replacement for good old R 12.
My advice, pump down the refrigerant into the condensing unit. disconnect the evaporator, check it with OFN on the working table and re solder all the connections, its an old evaporator and the problem will only get worse.
After you have finished, evacuate and run the system.
17-06-2008, 07:03 PM #3
Transvestites are men who like to eat, drink, and be Mary.
21-06-2008, 01:02 PM #4
thanks for the info .. now... Is there an epxoy to apply to small leaks for a temporary fix or no?
21-06-2008, 01:19 PM #5
i know of this product over here
http://news.thomasnet.com/fullstory/472941
never used it myself but know of a VRV system where this has been used and worked a treatPaul
"KEEP IT COOL"
21-06-2008, 03:58 PM #6
epoxy will do the job if its on a plate evap... but i would suggest you have a few large leaks if u need to charge every few weeks
21-06-2008, 06:29 PM #7
Dont put that sh*t in called superseal check this thread
http://www.refrigeration-engineer.co...ght=super+sealTransvestites are men who like to eat, drink, and be Mary.
21-06-2008, 11:37 PM #8
Several american companies do epoxy repair kits. Wagner, Rectorseal spring to mind.
Presume evaporator is aluminium? - Soldering is not really an option.
You will need to abrade paint and clean off any oil from area before using epoxy.
You will also need to recover refrigerant first, apply small vacuum to evaporator whilst epoxy is applied and allowed to set.
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
CARE refigerants by BOC
By dogma in forum RefrigerantsReplies: 8Last Post: 23-03-2010, 12:39 PM -
Help in finding high quality refrigerant leak detector
By AndyO in forum FundamentalsReplies: 5Last Post: 26-11-2007, 12:16 AM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM
