Results 1 to 12 of 12
    Oct 2003
    Alto, Mi
    58
    What's wrong with this picture?
    I was lucky enough to have a camera handy to capture this bit of genius!
    Once I caught an electrician tying a neutral to a defrost term/fan delay switch on a 230v freezer evap. Why? Because one of the wires is white....
    4,700
    Re: What's wrong with this picture?
    Hi Herm Medic.
    Its a little unclear or that could just be my eyes this morning?
    But is that what appears to be the evaporator or something else plugged into an outlet socket
    Sited just below the evaporator?
    Cheers Grizzly
    Jan 2008
    Norfolk - England
    95
    How about condensate drain going uphill!! or trap in condensate line in freezer!!!
    Split Croatia
    6,151
    Quote Originally Posted by MRcoolingMAGIC View Post
    This could be from another "plumber" which f***** it up.
    This a gravity drain for a condensate not a kitchen sink in which eventualy might find a chunk of a carrot.
    Maybe his condensate ends up in sewage and he need siphon to stop odors.
    Jan 2008
    Kent UK
    49
    514
    The box of fries on the the left is 2 months past its use by date.
    If it ain't broke, it doesn't have enough features yet.
    Damo
    Oct 2003
    Alto, Mi
    58
    That's the supposed to be the service disconnect screwed to the underside of the drain pan
    Oct 2003
    Alto, Mi
    58
    The wires go through the the pan and are sealed with caulk, so far....
    william_wye's Avatar
    william_wye Guest
    Why is there a GPO in the room??
    Forced draught instead of induced draught, add why the hell is there a 3 pin outlet supplying the drain heater.
    magoo
    Dec 2008
    South Africa
    9
    Maybe The evap has a sump pump mind u
    Dec 2008
    South Africa
    9
    Thumbs up Re: What's wrong with this picture?
    Like I said The Guy had a sump pump or re piped his liquid line for sub cooling
    Apr 2010
    295
    tell me its in china or some were like greece if a brit fridge monkey fitted that he deserves to be made a bog cleaner
  1. Wrong expansion valve installed
    By kentbf in forum Trouble Shooting
    Last Post: 02-03-2008, 08:49 PM
  2. Electronic controller probes wired wrong
    By Electrocoolman in forum Trouble Shooting
    Last Post: 12-11-2007, 06:39 PM
  3. Whats gone wrong!!!!!
    By jbear in forum Transport
    Last Post: 14-03-2005, 12:17 AM
