Thread: heat load
12-06-2008, 11:43 PM #1
heat load
please help,what is 60watts as the per cu,meter
how big is the cu,is it a meter.
12-06-2008, 11:49 PM #2
Re: heat load
What sort of Technician are you ?
I understand that English is not your native language but your questions are most confusing.
What is 60 Watts as the cubic metre ? This has no meaning whatsoever.
Watts = power
Cubic metre = volume
How big is the cubic, is it a metre ? A cube is a shape and the sides can be measured in any dimensional unit that you wish; mm, cm, m, inches, feet, thumb prints, arm lengths etc.Brian - Newton Abbot, Devon, UK
13-06-2008, 02:25 AM #3
Re: heat load
Brain, this goes back to another thread where someone suggested the energy density to design cold storage rooms.
Ray Ang SM,
As a side note, I would like to emphasize this sort of design procedure should NOT be used. It does not take into account aspects of a heat load that can greatly vary from location to location or application to application.
Just because it looks easy, does not mean it should be used for all, or any application. This is a good way to get yourself into expensive trouble.If all else fails, ask for help.
13-06-2008, 11:31 PM #4
Re: heat load
thank us iceman you really a nice guy.
14-06-2008, 02:55 AM #5
Re: heat load
are you calculating heat load you have in order get size of the A/Cunit if it the case you you mean100W per sq/meter
14-06-2008, 06:12 AM #6
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,175
- Blog Entries
- 6
- Rep Power
- 36
Re: heat load
When ever someone post question about heat load, always pop up someone enthusiastic with these ridiculous rules of thumbs.
How on earth you know about what building type and construction we deal here when there is no 1 word about that.
Suppers your euphoria, and keep these rules for yourself, if you don't know about what you are talking.
Educate yourself about heat load calculations, then (and only then) you could apply some rules of thumb in certain well known situations but not in situation like this where there is no one word about conditions and building.
Start with insight what it is about here
15-06-2008, 08:09 AM #7
Re: heat load
Heat Load Selection for EOT Cabin A/C in Steel Plants
By Samarjit Sen in forum Tools and CalculatorsReplies: 12Last Post: 19-11-2010, 01:17 PM -
Capacity control
By sparrow in forum TrainingReplies: 44Last Post: 18-01-2010, 08:49 PM -
Some information on the aplication of suction gas/liquid line heat exchangers
By SteinarN in forum FundamentalsReplies: 5Last Post: 14-09-2009, 07:33 AM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM
