    labrosse's Avatar
    labrosse Guest
    Potential Relay not staying open
    I just got a new 3/4 HP 120volt compressor for a freezer. However the relay tries to close every 2 seconds or so over and over again. By doing this it continually is trying to engage the S side of the compressor. There is a Start capacitor before the relay but it doesn't seem to keep sufficient voltage for the relay to stay open.
    The relay is rated is listed on this page.
    http://www.jard.com/prelays.htm model jpr-63
    Please help.
    dave
    87mustang's Avatar
    87mustang Guest
    Re: Potential Relay not staying open
    Relays ( as we are talking potential type ) will short cycle for the following reasons,
    1- incorrect application
    2- low EMF (counter EMF)
    3- not positioned correctly (some are positiom sensitive)
    4- voltage problem from source or through the OLD thermostat.
    5- bad (?) compressor windings
    6- poor electrical contacts/path
    and there is always the famous- it came that way, and is defective.
    Apr 2005
    INDIA
    63
    84
    Mr, Lab.
    I thing U dont know any thing about compressor ?
    better contact a tech and get it tested!
    In my opinion,
    a, faulty starting cap,
    b, faulty olp,
    c, compressor motor is short,
    Regards,
    beni joseph.
    Sep 2003
    ISRAEL
    72
    4,248
    I will have to agree with Mr Joseph on this one.
    I presume olp is over load protector?
    Chemi
    Jun 2005
    California
    394
    Potential relays are wired in parallel with start windings and are therefoe controlled by the back EMF of the start winding. You aparently have a mismatch If the start winding or the capacitor was defective you not be able to start the compressor. P.S. the start cap has nothing to do with the relay its function is to increase the phase shift between the run and start windings
  1. Hinari and how far to open valves
    By stryker in forum Air Conditioning
    Last Post: 14-04-2008, 01:47 AM
  2. voltage drop on relay
    By Temprite in forum Electrical
    Last Post: 30-01-2006, 07:55 PM
  3. Open Type Compressors
    By shogun7 in forum Air Conditioning
    Last Post: 07-01-2005, 09:15 AM
  4. Freezer Potential Relay not staying open
    By labrosse in forum Trouble Shooting
    Last Post: 28-10-2003, 01:53 AM
  5. Alternating Relay Circuit
    By herefishy in forum Industrial
    Last Post: 09-07-2002, 06:03 PM
