Results 1 to 13 of 13
    Mar 2006
    Spain
    21
    Using A Recovery Machine To Clean Pipes
    Hi Everyone
    I have a few wall split systems to replace that are on R22, they use pipework that is built in to the walls which I need to re-use, I have to replace the systems with R410a kit and would like to know the best way to clean the pipes before installing the new systems, I have a recovery machine and OFN kit, normaly I change the lines but in this instance that is not possible. Thanks in advance.
    Clive
    May 2008
    66
    802
    Re: Using A Recovery Machine To Clean Pipes
    Yep, using a recovery machine is good,but look if it has the function of pumping liquid around the pipes.
    not all machines do.
    use the correct type of cleaning medium, its not the R22 thats the problem, its the oil from the compressors, and the new ones on R407c or R410a are very different than R22.
    make sure the are clean - clean.
    Ice
    Mar 2006
    Spain
    21
    Thanks Icecube51
    any sugestions for the cleaning medium?
    Clive
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by Clivo View Post
    Hi Everyone
    Clive
    You should also check that pipe thickness is suitable for use with R410A.
    Jun 2005
    Lancs
    61
    Thanks Icecube51
    Clive
    I have used endoflush flushing agent for cleaning systems after burnout. You would have to check if this would be suitable for your requirements. You would also need a suitable endoflush pump. It's expensive but if you have no other alternative then you have little choice.
    Steve
    May 2008
    66
    802
    there are many cleaning mediums available, just look for one that takes good care of oil and burnout residue.
    have fun
    Ice
    Mar 2007
    Warwickshire UK
    723
    21
    Some new split systems are designed to be used with old R22 interconnecting tubes & have a special filter to remove any contamination in the old tubes.
    For instance Mitsubishi Mr Slim Power Inverter units incude this replace technology as standard.
    You need to check that your pipe sizes & max pipe lenght are within limits.
    Then at first start up one dip switch setting makes the unit run in clean up mode & pass all refrigerant through the replace filter for 2 hours test run.
    After 2 hrs the unit shuts solenoid valve & any contamination is permanantly trapped & isolated from the system in the replace filter.
    Then the system is available for normal operation.
    Easy peasy japanesy
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by Thermatech View Post
    Easy peasy japanesy
    I am not impressed with that solution.
    You are first contaminating new, virgin system and then cleaning it. S h i t t y approach, by my standard!
    Jun 2005
    Lancs
    61
    it's a ****ty approach by most of our standards , but hey when needs must and there are no other viable alternatives it's still an approach . shall we say a stagger in at least a somewhat forward direction
    May 2008
    66
    802
    looks like a brand commercial to me, but hell, anything is for sale,as long as the find D****SS ho by it.
    Ice
    Mar 2006
    Spain
    21
    Have looked at the mitsi technology replace kit, I have to agree that it must be a compromise, think of all that crud first off racing round the brand new kit then sitting in the system !. I'll go down the cleaning route thanks.
    Hard enough to get any sort of tech advise on the phone in Spain without trying to prove you removed all the oil and residue from some old pipes when you claim on a guarantee,
    Thanks for everyones input.
    Clive
    GXMPLX's Avatar
    GXMPLX is offline Veteran Poster I am starting to push the Mods: of RE
    May 2008
    weston
    348
    First check pipe thikness verify if adequate for R410a, then do thorough pressure testing. You should use R141b for cleaning but you will never be sure! The only way to clean is circulating R410a for very long time and you must do this with the same equipment. Install Suction and/or extra liquid line filters sized so that pressure drop is within limits. Check these filter after reasonable time, replace and open and inspect the used filters if they are clean you are 98% sure the system is OK. Then eliminate the extra filters.
    Mar 2004
    624
    21
    I,ve used Endo flush for this problem,I pumped it through with a oil pump and kept on pumping it through until it came out clean then blew it through with ofn.Search older threads and you,ll find more answers as this has been covered before.
    http://www.refrigeration-engineer.co...ght=endo+flush
    Regards Bernard
  1. Use of same recovery machine for different oils
    By Contactor in forum Fundamentals
    Last Post: 17-03-2008, 01:02 AM
  2. complete System Recovery
    By absolute-zero in forum Computers & the Internet
    Last Post: 20-01-2008, 06:03 PM
  3. Recovery Machine
    By gwilliamson in forum Air Conditioning
    Last Post: 04-09-2006, 09:54 PM
  4. Refrigerant Recovery Machine
    By iceman007 in forum Tools and Calculators
    Last Post: 29-03-2004, 10:10 PM
  5. Cattabriga Ice Cream Machine
    By Abe in forum Trouble Shooting
    Last Post: 26-04-2003, 01:06 PM
