Results 1 to 14 of 14
    Dec 2006
    106
    Samsung SR-L3, error code "rd"
    I got a customer who has a Samsung domestic fridge/freezer (SR-L3) not working at all. This is what occurs:
    - You power up the Samsung
    - Everything starts up as normal, the compressor, the readout, the light inside, everything seems fine
    - After a couple of seconds, all of a sudden it stops, and the read out reads "rd".
    I suppose all I really need to know is what "rd" stands for, I’ve rang Samsung, but the line has been engaged since 2:00am with an automated message "we're out to lunch, please leave a message or try later"!
    Any ideas welcome
    Split Croatia
    57
    6,151
    36
    Re: Samsung SR-L3, error code "rd"
    Try again, later!
    Dec 2006
    106
    Yeah!, but it’s 5 o'clock now, so they've gone home, still the same message though, "gone to lunch etc", a long lunch!, properly a phone system error. I just wondered if anyone could help me so I have a bit of information for tomorrow morning.
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by Rtic View Post
    Try here:
    http://www.ukwhitegoods.co.uk
    Dec 2006
    106
    I don't understand how that website will help me?
    Split Croatia
    57
    6,151
    36
    That site has forum who deal whit questions like yours.
    http://www.ukwhitegoods.co.uk/modules.php?name=Forums
    Jan 2008
    Kent UK
    49
    514
    I would say that "rd" is refrigerator defrost error whereas "fd" is freezer defrost error.
    I could be wrong,but if you dont have any luck ringing Samsung back tomorrow,give Watchdog a call,they could make another episode out of lax customer service.
    If it ain't broke, it doesn't have enough features yet.
    Damo
    Dec 2006
    106
    Quote Originally Posted by Chunk View Post
    Good call, I'll give watchdog a call tomorrow! The "rd" and refrigerator defrost could be right as well, in fact that an intelligent guess, thanks!
    Jul 2007
    Australia
    1,845
    Rd is air damper iced up fault.
    The damper in the freezer spins around to close/open the air from the freezer to the fridge.
    It ices up from time to time, or the damper motor, or sensor that reads it's position fails.
    Very common fault, there's a repair kit with a new sensor, damper and bigger heater that's needed to be fitted to nearly every RL33 fridge down here.
    If that doesn't work, the damper motor it's self is failing.
    The dampers used in these fridges aren't an open/close type flap, but a damper that endlessly spins around, hence needing a magnetic position sensor to tell if it's open or closed. The "Rd" fault means it's not spun to the position it should be in due to icing up or motor failure, or it can't detect it, due to sensor fault.
    dardan's Avatar
    dardan Guest
    I also have the same problem on my Samsung RL39WBMS.When I power up it works fine, after some seconds it stops and shows the rd error.I also checked the damper and it spins around,so I think the problem is to the magnetic sensor,but I don't know how to check the sensor.Maybe you can help me ??
    May 2008
    U.K.
    73
    The magnets often drop off the motor shaft!! It's a little black thing about 2mmx5mm
    dardan's Avatar
    dardan Guest
    yeah I know where is the magnet.But I want to check magnet's sensor because I think the problem is to sensor,but here we don't have these sensors to put a new one so I must be sure if the fault is to sensor . thanks
    Jul 2007
    Australia
    1,845
    Well I assume it's just a switch, so with be open or closed circuit in the presence of a magnet.
    lekiti's Avatar
    lekiti Guest
    Paul Thanks for the information. I removed the the engine and glue the magnet back on the positioner an d the fridge is working fine again.
    I don't understand why this message is not inside the manual of Samsung.
    This cost me 1 tube of glue.
    Thanks men!
