Results 1 to 14 of 14
Thread: ammonia tubing
11-06-2008, 08:39 AM #1
ammonia tubing
Dear All,
Is there any manufacturer of flexible tubing for ammonia LP/Hp/Op switches.
rajkumar
11-06-2008, 01:38 PM #2
Re: ammonia tubing
What you are looking for is small charging hoses. Instead of the larger versions used for pumping refrigerant into the system, you simply want a much smaller one.
So what ever you use for for charging a system would work for the pressure switches, although I would ask for armored hoses with stainless steel braiding on them for abrasion protection.Last edited by US Iceman; 11-06-2008 at 01:39 PM. Reason: spelling
Re: ammonia tubing
Not sure I would use any kind of "rubber" hoses on ammonia.
we use armoured hydraulic hoses for charging ammonia, as long as it's gas it's fine, but after two or three uses with liquid ammonia they start getting "eaten up" I have taken them apart at the places they start leaking, no material missing, seems like the ammonia goes through the material.
I would rather go with the 3mm steel pipes that come with the danfoss KP15A, or the MP55A.
They can also be purchased seperately.
or I would use plain old 6mm pipe-Cheers-
Tycho
12-06-2008, 06:03 AM #4
Re: ammonia tubing
I am looking for tubing for pressure gauges and Safety switches.
We normally uses 6mm steel pipe. Can we use flexible tubing for the same?
Who are the manufacturer of the same?
12-06-2008, 11:49 AM #5
Re: ammonia tubing
I don't think it is a good idea to try any permanent installation of flexible tubing. If the steel tubing is corroding I recommend seamless stainless steel tubing as a replacement.
12-06-2008, 11:57 AM #6
Re: ammonia tubing
Thanks for solution
12-06-2008, 12:06 PM #7
Re: ammonia tubing
If this is the direction you plan to take please make sure that you choose the right compression fitting. I use "Swagelok". Good Luck.
12-06-2008, 03:27 PM #8
Re: ammonia tubing
My preference is the use of stainless steel seamless hydraulic tubing and the Swagelok tubing fittings. Then if you use a tubing bender to install the tubing in nice manner they tubing will last for a long time.
You do have to be careful with the mounting of the tubing to ensure it does not rub on other surfaces also.
Can't say I have seen a charging hose start to leak after three uses though.If all else fails, ask for help.
Re: ammonia tubing
Didnt have time to look it up yesterday, but here's the link to the tube I was talking about.
http://www.danfoss.com/Products/Prod...eno=060-007866-Cheers-
Tycho
12-06-2008, 04:37 PM #10
Re: ammonia tubing
Thanks Tycho . The hoses in the link look similar to something Copeland had about 20 years ago. For ***** components I liked this approach a lot better than the small copper capillaries on the pressure switches.
12-06-2008, 04:47 PM #11
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
13-06-2008, 02:42 AM #12
Re: ammonia tubing
Originally Posted by nike123If all else fails, ask for help.
13-06-2008, 10:15 AM #13
Re: ammonia tubing
The danfoss capilliary connections are good for transducers , gauges and pressure switches. They dampen pressure flucuations which can cause damage (like a transducer on liquid pump discharge if it cavitates causes premature failure).They are cadmium plated, but stainless tube lasts forever and always looks good.
14-06-2008, 02:18 PM #14
Re: ammonia tubing
I would like to ask if You have any catalogues with technical data for freezing tunnels and if yes, can You provide these catalogues for me. If not, can You please tell me or give me directions where I can find the information I need.
Thank You in advance
Regards,
eng. Miroslava Rasheva
contaminants in ammonia systems
By Johnny Rod in forum RefrigerantsReplies: 29Last Post: 17-10-2011, 05:26 PM -
Want to be trained as an ammonia operator
By Randy Williams in forum NH3Replies: 7Last Post: 26-11-2008, 08:15 PM -
Releasing ammonia into the environment.
By Tycho in forum NH3Replies: 21Last Post: 03-02-2008, 05:10 PM -
Ammonia and CO2 reactor
By gwapa in forum NH3Replies: 18Last Post: 07-01-2007, 04:50 PM -
New Ammonia Certification in United States
By JerrydNH3 in forum NH3Replies: 11Last Post: 15-08-2006, 03:10 PM
