    runce's Avatar
    runce Guest
    Thermoelectric P.O.U. water fountain
    I am currently involved in a university project to produce a domestic water chiller. The unit has a tank of approximately 2 to 3 liters (there is a little flexibility in this). Doesn't sound too difficult yet does it?! However, to keep cost down we are trying to utilise solid state refrigeration (ie thermoelectric) to cool the tank, as appose to a vapour cycle system. The tank is to be cooled to 15C below ambient. Does anybody have any experience of thermoelectric chilling of water or any suggestions? I am familiar with vapour cycle refrigeration but have virtually no experience of thermoelectric systems.
    runce's Avatar
    runce Guest
    Further to what I've said above, could thermoelectrics be used to generate any significant electrical current from a cold water (5C) / hot water (95C) temperature difference?
    Aug 2001
    1,046
    You may be looking for Peltier Effect heat pumps.
    Try the link below, also, as I recall, RS Components had a data sheet on their use some while ago ? though I cannot say if it is still available.
    http://www.hawco.co.uk/news_details.asp?NewsID=62
    Also search Peltirer effect on Google
    Argus
    ________
    medical marijuana strains
    May 2002
    The Netherlands
    48
    274
    23
    I have been working with peltiers/TECs. These do work for your application, but you have a tradeoff: either use a single TEC near it's maximum rating, and experience a low COP, or use multiple TEC's at a fraction of their maximum rating, and experience a higher COP. The latter way is as expensive as a small vapour compression system.
    You might want to check out the design software from Kryotherm.
    About generating electric current with a TEC: when a temperature difference is applied, a voltage will appear. However, this voltage source has a fairly huge internal resistance, so actually drawing current from it is hardly possible.
    Feb 2004
    US of A
    22
    I have seen a canned whip cream chiller based on peltier that looks like a small plastic drum in a supermarket. It is apparently provided by the whip cream vendor as the whole thing is decorated specifically for the product.
    It doesn't hold that many cans of whip cream. The usable space is rather small and the whole thing sits on what I would guess to be a hollow plastic cylinder.
    There's a pair of fans whirring at the top.
  1. Hoshizaki Ice Maker
    By Abe in forum Legal-Business-Marketing
    Last Post: 01-05-2010, 03:27 AM
  2. Fact or Fiction
    By david.findlay in forum Fundamentals
    Last Post: 09-03-2009, 06:19 PM
  3. pure water from air
    Last Post: 26-02-2009, 12:25 PM
  4. open cycle R718 A/C that also provides high purity water?
    By star882 in forum Technical Speculations
    Last Post: 27-07-2006, 04:18 AM
  5. Building a wine cabinet
