Results 1 to 17 of 17
Thread: high suction pressure
09-08-2009, 12:42 AM #1
ive been working on a goodman a/c thats about 6 yrs old suction pressure is 200 head pressure is 200. did a amp check on the compressor it 23. rla is 12.1 . the amps seemed high is this normal? evaporator is a little dirty but not bad. inside fan is blowing good. thanks for any info
09-08-2009, 12:47 AM #2
Re: high suction pressure
It would appear that the compressor has stalled and drawing lock rotor amps.
09-08-2009, 01:31 AM #3
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
09-08-2009, 01:33 AM #4
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
09-08-2009, 01:44 AM #5
no, this is not a heat pump.
09-08-2009, 04:17 AM #6
Let me get this straight. The compressor is running and the suction and head pressure are the same? If this were a hermetic with this problem, I would say that the discharge line inside the compressor has broken and the refrigerant is recirculating inside it. If this is the case, suction line entering will be warmer than expected and discharge line leaving will be cooler than expected.
09-08-2009, 08:22 AM #7
Suction Pressure and discharge pressure both are 200 PSI seems that the system might have been recently topped up with refrigerant and it appears overcharged as both suction and discharge are same.
Please remove refrigerant till suction is around 60 to 70 PSI for R-22 and check.
09-08-2009, 09:19 AM #8
There are following possibilities
1. Relay is functioning wrong
2. The run and start winding getting short, check for Resistance of both
3.the discharge line inside the compressor has broken and the refrigerant is recirculating inside it and for verification you can check the discharge will be colder than compressor dome temperature.
4.You can also check for noise (abnormal) from the compressor.
Amit Saxena
09-08-2009, 09:49 AM #9
09-08-2009, 01:09 PM #10
ill go a carton that the start capacitor is open circuit,dont reckon locked rotor amps are high enough,and op has hearing problems,broken pipe would be under amp i reckon saturated.
cheers fellasLast edited by lowcool; 09-08-2009 at 01:12 PM. Reason: had belt drive single phase to this current havent done a tin can but
09-08-2009, 05:12 PM #11
Of course with broken compressor valve(s) current drawn is much less than the rated one.
09-08-2009, 05:39 PM #12
Are we assuming the compressor is a recip? Maybe it is a scroll.
09-08-2009, 08:17 PM #13
what are the standing pressures and what happens to these when the comp gets power?
can you pump test the comp?
10-08-2009, 03:40 AM #14
thank you all for the help
10-08-2009, 05:32 AM #15
Low Cool.
You are a cool guy, 99% of posts would not even remotely understand your post. But I do and your on the button.,
10-08-2009, 01:30 PM #16
what you been on magoo?
less time speakin,more time for drinkin!
did have a chuckle over garys post didnt think of that one,i might see a goodman compressor one dayLast edited by lowcool; 10-08-2009 at 01:35 PM.
19-08-2009, 12:10 PM #17
There are only 2 cases which we could get the said pressure's reading. It's ether compressor's valves are broken or a broken discharge line inside the compress's dome. which mean the compressor is pumping the refrigerant to the suction line directly ,this case will increases the drawn amps where the broken valve decreases the drawn amps
need help! compressor kicking out on high pressure
By SloFuse in forum Trouble ShootingReplies: 16Last Post: 19-08-2009, 04:46 PM -
Pressure drop through the suction line accumulator?
By frank721 in forum Technical DiscussionsReplies: 61Last Post: 14-07-2009, 06:06 AM -
High Suction Temps
By freezerman11 in forum Trouble ShootingReplies: 4Last Post: 30-06-2009, 08:11 PM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM
