Results 1 to 17 of 17
Threaded View
12-05-2009, 07:48 PM #13
Re: need help! compressor kicking out on high pressure
sounds like to me if your getting high pressure readings like that , then you could have nitrogen in the system.In regards to the leak you should have found it with 350 psi of pressure , has it got a pressure release valve and blowing it of that way due to possible non condensables in system.
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM -
High Side Pressure is ...
By SULTAN in forum Trouble ShootingReplies: 5Last Post: 14-08-2007, 12:53 PM
