Results 1 to 2 of 2
    Chilly Charlie's Avatar
    Chilly Charlie Guest
    Can we run a freezer on a battery?
    Hi guys,
    I am hoping someone out there can help with my problems? I have an ice cream freezer with glass sliding tops and want to run it on a leisure battery or similar, with an inverter.
    It has a capacity of 163L and is a 240v. It's rated frequency is 50Hz with a refrigerant of R600a(42g). The energy consumption is 0.95KW-h/24h.
    I have tried running it through a 700w inverter on a 110AH leisure battery but every time the freezer kicks in, the freezer goes off every couple of seconds?
    I need to power the freezer for around 6 to 8 hours ideally?
    Any ideas please?
    Many thanks,
    Paul.
    Split Croatia
    57
    6,151
    36
    Re: Can we run a freezer on a battery?
    Quote Originally Posted by Chilly Charlie View Post
    Hi guys,
    Any ideas please?
    Many thanks,
    Paul.
    You need to have inverter capable to deliver current to compressor motor at start of operation which is 6 times greater then when compressor reach his steady operation state. Also, this load is inductive and your inverter should be dimensioned for that fact also.
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  2. Freezer compressor running 20 Hours/day
    By rickcw in forum Domestic
    Last Post: 08-03-2008, 11:50 PM
  3. Need help quick with walk-in freezer issues!
    By hysiderafter in forum Commercial
    Last Post: 12-12-2007, 12:57 AM
  4. Trolley freezer & blast freezer
    By smpsmp45 in forum NH3
    Last Post: 25-08-2007, 07:29 AM
  5. Freezer efficiency questions
    By M_Q in forum Fundamentals
    Last Post: 20-03-2007, 04:38 PM
