Results 1 to 13 of 13
    Jan 2008
    34
    113
    12
    Have they any knowledge?
    A few days ago i was with a install team, i was putting in the mains and commisioning. On the test run one daikin unit would not run just sat there without any faults which was strange but at the same time the project manager turned up and decided he was going to diagnose the unit. His first input was we had to re pressure test the unit, when the unit had 200psi standing and had only just been charged, so i disagreed with him so he got on the ladders felt the flare nut and said its leaking because it was a little wet, this could be anything. next he said i think we need to change the fan motor, WHY? GOD ONLY KNOWS. Then he topped it off by saying to me what is the back pressure? how can i tell that when it aint running.Tell me is there any more clowns like this around.
    Mar 2008
    49
    273
    11
    Re: Have they any knowledge?
    Definition of a project manager
    A nob
    Transvestites are men who like to eat, drink, and be Mary.
    Jun 2005
    California
    395
    14
    Don't say anything, just do as he says and let the results speak for themselves!
    70
    10,650
    52
    Let me add on to that comment...
    Do what he says but get it in writing first.
    You'll find that he won't ask you to do anything then.
    Jun 2005
    California
    395
    14
    Excellent thought!
    Jul 2001
    Sydney, Australia
    764
    Quote Originally Posted by leegally1983 View Post
    yep, the trade is full of them - they are good value, you just have to learn to laugh it off
    ...and she said "give it to me you big fridgie"
    Jul 2008
    Illinois
    9
    You're in England? I thought only us Yanks had idiot project managers like that!
    In my younger days, and in a different field, we had a complcated piece of machinery fail. After a morning of headscratching and poking, I had worked backwards enough through the system to identify a timer that was failing. The timer had failed because the grease in the clock motor had hardened over the years and caused it to overheat, cooking the insulation of the windings.
    Well the problem was the part cost a little bit of money, so to save a handful of dollars the manager asked me to clean and re-lubricate the motor and reassemble it, then put it all back together. Now realize we are looking at 3 or so hours of disassembly and an equal amount for reassembly over a $30 part that is already letting the smoke out, it's kinda a false economy. Anyway, I pointed this out and got the reassurance that I'd still be paid if it needed to be re-done. So back everything went and sure enough by the next morning it had failed, so I had to repeat the previous day.
    At least all the bolts came out easier.
    Dec 2006
    Mansfield
    232
    I had a situation once the project guy wanted to witness the pressure test.
    When I had charged the ofn to the correct pressure I called him over only for him to ask me what he was supposed to be looking at.
    Priceless
    Keep em coming
    PP
    Mar 2006
    Merate (LC) - Italy
    47
    2,553
    Abraham Lincoln (attributed): 'Tis better to be silent and be thought a fool, than to speak and remove all doubt.
    Apr 2006
    stafford
    37
    986
    14
    once went to over see a Crane lift of steels off a roof in London on an install were the planing application had been turned down so all the steels and outdoors had to come down,the lift went well until the flat bed turned up,its was a right old dog but the driver seemed happy to load it up,once loaded the springs were nearly flat and the steels were overhanging by a mile! there was no way i was letting this go back up to the Midlands overloaded and unsafe, so i rang the gaffa and told him the story,his answer cut the steels in half to stop the overhang,my answer why does that make them lighter?
    Paul
    "KEEP IT COOL"
    msahmed's Avatar
    msahmed Guest
    Glycol vs Brine solutions
    anybody got idea what is the difference between glycol and brine. i need some tips on brine ice rink freezing fluids for brine chillers
    thanking you guys
    msahmed@coil-tech.com
    Mar 2006
    Merate (LC) - Italy
    47
    2,553
    Glycol is the compound that most frequently is used diluted with water, forming brine.
    Brine is actually a solution, glycol is a chemical compound.
    Oct 2003
    56
    5,519
    28
    Re: Glycol vs Brine solutions
    Quote Originally Posted by msahmed View Post
    thanking you guys
    Hijacking this thread and wrong section
  1. Level 2 NVQ
    By Danny11 in forum Air Conditioning
    Last Post: 21-08-2010, 10:22 PM
  2. NOTHER NEWBIE with vehicular air-con knowledge.
    By pete2bram in forum New to RE
    Last Post: 11-03-2008, 12:38 AM
  3. Knowledge on -40 to -180 deg units
    By cbxkev in forum Technical Discussions
    Last Post: 05-05-2006, 09:06 AM
  4. NH3 Knowledge
    By DoBeR in forum Training
    Last Post: 11-11-2004, 05:40 PM
