Results 1 to 15 of 15
Thread: Spiral freezer
    Jan 2008
    India
    14
    Spiral freezer
    Hi everyone!
    Can anyone had experience with spiral freezer.
    Can we use Spiral freezer with nh3 gravity flow system instead of liquid overfeed system. Freezer is FMC make.
    regards
    Auckland
    74
    3,357
    37
    Re: Spiral freezer
    Hi Raj
    Yes the coil can be gravity fead, but needs a surge drum approximately 3.5 metres above coil, check that coil circuiting suits gravity feed. Go back to FMC Foodtech and discuss options and design.
    Magoo
    Aug 2005
    5,302
    Re: Spiral freezer
    I'm curious why you want to use a gravity flooded system instead of liquid overfeed. Are you changing this?
    3,355
    Re: Spiral freezer
    Their latest design is gravity feed,but to change it would be like starting all over again.Big$$
    Aug 2005
    5,302
    Re: Spiral freezer
    Why are they using gravity flooded Ranger1? It seems like a waste of good ammonia.
    Jun 2001
    N.Ireland
    1,630
    Re: Spiral freezer
    Hello Iceman
    they may call it gravity, but it is probably liquid overfeed using an injector and a high pressure liquid line (like the Mojo surup cooling plants). From memory FMC owns frigoscandia who developed this system, I think it is on the FMC web site.
    Nothing new but a well applied old technology.
    The advantages of this system are.
    1/no pumps
    2/smaller dry rather than wet suction returns.
    3/No insulated pumped liquid lines needed.
    Kind Regards Andy
    3,355
    Re: Spiral freezer
    Andys description is right. liquid pumps were ok but severe on pulldown causes a lot of cavitation as well
    Aug 2005
    5,302
    Re: Spiral freezer
    Quote Originally Posted by Ranger1
    ...liquid pumps were ok but severe on pulldown causes a lot of cavitation as well.
    I've seen this occur also, but this is a design flaw and not the pumps fault.
    3,355
    Re: Spiral freezer
    You could call it a design flaw, but it starts up hot every day and try to pull down to temp as quick as possible.
    Liquid pump cant help but cavitate in most cases.
    System Andy describes is cheaper,as no accumulator/liq pumps.
    High pressure liquid line is insulated as system is usually single stage economized.Surge drum is in refrigerated place, so no need to insulate.I have worked on one new style breifly and hot pull down still has its problems if you load up comps to quickly (liquid carryover).
    Nov 2007
    India
    74
    Re: Spiral freezer
    Thanks andy,
    Pl. forward the sketch for the same.
    Jun 2001
    N.Ireland
    1,630
    Re: Spiral freezer
    Quote Originally Posted by Rajkumar View Post
    Thanks andy,
    www.fmctechnologies.com/upload/lvsfrigopakrefrigeration.pdf
    Nov 2007
    India
    74
    Re: Spiral freezer
    Thanks Andy the literature is very useful.
    Auckland
    74
    3,357
    37
    Re: Spiral freezer
    Speaking from years of experince with these FMC systems, the first start on any day should be slow and easy, at least 1 hour before product enters spiral, pump feed or gravity or LVS, the same rule applies, PLC rograming should control the fact. LVS is far superior, but FMC/ Frigoscandia/ now JBTC, guard LVS to the extreme.
    In short don't load compressor quickly on first start for day, and everything will go great.
    magoo
    Auckland
    74
    3,357
    37
    Re: Spiral freezer
    You are all very quite on this topic/post.
    magoo
    Jun 2006
    jiansu
    38
    Re: Spiral freezer
    you can link. www.worldbase.cn
  1. Freezer compressor running 20 Hours/day
    By rickcw in forum Domestic
    Last Post: 08-03-2008, 11:50 PM
  2. Need help quick with walk-in freezer issues!
    By hysiderafter in forum Commercial
    Last Post: 12-12-2007, 12:57 AM
  3. Trolley freezer & blast freezer
    By smpsmp45 in forum NH3
    Last Post: 25-08-2007, 07:29 AM
  4. Project needs a freezer box.
    By NC-Joey in forum Fundamentals
    Last Post: 16-08-2007, 01:27 PM
  5. Freezer efficiency questions
    By M_Q in forum Fundamentals
    Last Post: 20-03-2007, 04:38 PM
