    May 2008
    Uk
    Lp switch Settings
    How do iI set an LP switch with a differential for a coldroom.What sort of pressures do I require to maintain a temperature of bettween 0 and 5 degrees with the compressor cutting out and kicking in normally.
    11,025
    Re: Lp switch Settings
    Are these exam questions coming round again?
    With the LP switch - read the instructions that come with the switch.
    What sort of refrigerant are you using?
    Mar 2008
    54
    273
    You fit a thermostat for an accurate control of temperature as pressures vary with temperature and therfore an lp control switch will require constant adjustment and readjustment.
    rgs phil
    Transvestites are men who like to eat, drink, and be Mary.
    May 2008
    Uk
    Thanks ,Its R22
    Feb 2008
    Las Vegas, NV
    67
    330
    Quote Originally Posted by Raswes View Post
    How do I set an LP switch with a differential for a coldroom.What sort of pressures do I require to maintain a temperature of bettween 0 and 5 degrees with the compressor cutting out and kicking in normally.
    I read your question as: you need to control a cooler with the LPC and you need the pressure settings.
    Let's assume this is a small beverage cooler with a forced air evap. I'll also assume you were giving celsius temperatures being it's R-22.
    0 C = 32 F
    5 C = 41 F
    You could start with these settings and adjust as needed for proper temps and to prevent short cycling.
    cut in: 64 psi
    cut out: 34 psi
  1. H/p L/P switch settings
    By bernard in forum Commercial
    Last Post: 13-06-2010, 10:06 PM
  2. flow switch connection
    By afeef in forum The Trail of Tears
    Last Post: 23-12-2009, 06:55 PM
  3. Low Pressure Cut-off switch on Liquid line
    By Vishnukurup in forum Air Conditioning
    Last Post: 03-12-2008, 09:34 AM
  4. Hermetic analyzer " ANNIE" how do they work
    By kengineering in forum Tools and Calculators
    Last Post: 02-03-2008, 06:10 PM
  5. address settings.
    By bangoman in forum Air Conditioning
    Last Post: 19-01-2008, 04:14 AM
