Thread: Leak in Leer Walk in cooler
03-06-2008, 01:32 AM #1
I have a water leak coming down through the vent where th fans are. I own restaurants and if i need to call repairman i will. but thought this might be something we could fix.
03-06-2008, 11:27 PM #2
Re: Leak in Leer Walk in cooler
Yep it could be that you could fix it. If you don't try then you'll never know.
04-06-2008, 01:20 AM #3
Well, I read your user name and you must be a Georgia Bull "Dawg". That's okay, I'm from that area.
I suggest calling your local refrigeration contractor to take a look. He can spot any potential problems with the complete box and system. Water coming from the evap could have other causes than just an ordinary water leak.
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
Evasive gas leak
By Feeze in forum Technical DiscussionsReplies: 24Last Post: 18-08-2008, 07:22 AM -
walk in cooler evaperator keeps freezing up
By ewart in forum Trouble ShootingReplies: 21Last Post: 30-07-2007, 09:30 PM -
walk in cooler EVAPORATOR coil icing up
By kurt854 in forum FundamentalsReplies: 5Last Post: 14-06-2007, 07:28 PM -
Walk in Cooler (short cycling)
By Brandon in forum Trouble ShootingReplies: 11Last Post: 05-05-2003, 11:43 AM
