    May 2008
    Australia
    Vacuum Pump in a Hazardous Area?
    A customer has asked us to, in our proposal, include a vacuum pump for a Propane based industrial refrigeration system (quite large >5MW). All the gear in the refrgeration system, motors, solenoid valves, controls etc are rated for hazardous areas (Ex'n', Ex'd' Ex'i' etc). What about the vac pump? I presume that it either needs hazardous rating or during servicing two guys are needed one operating the vac pump and the other monitoring the level of HC in the air?
    Is there such a beast as a Hazardous rated vac pump?
    2,578
    29
    Re: Vacuum Pump in a Hazardous Area?
    Have you investigated a vac pump that has a pnumatic motor.The only thing you need then is compressed air line to run it.
    Mar 2005
    71
    639
    14
    Why not just get a XP or flame proof motor and static proof belts fro the unit. Put all of the controls in a flame proof box and them wire it in with the proper coded wiring. The simple approach is to place your unrated vacuum pump in an unrated area and pipe over to the unit.
    Ken
    Oct 2007
    w.mids
    43
    110
    11
    I work in hazardous areas also, how about a long length of 3/8 inch coiled pipe to a safe area?
    Put the screwdriver down and step away from the expansion valve !!!! OK Gary i won't touch it unless instructed.
  1. Vacuum Pump CFM
    By w.l.ong in forum Technical Speculations
    Last Post: 27-10-2008, 02:20 PM
  2. inverters pulling vacuum
    By bangoman in forum Air Conditioning
    Last Post: 05-02-2008, 09:12 PM
  3. SL/SB-400 Pump Down Procedures
    By absolute-zero in forum Transport
    Last Post: 29-01-2008, 09:27 PM
  4. Vacuum pump cleaning and POE!
    By The MG Pony in forum Fundamentals
    Last Post: 31-03-2007, 06:06 PM
  5. car engine oil in compressor used as vacuum pump for laser
    By star882 in forum Technical Speculations
    Last Post: 05-11-2005, 02:09 PM
Tags for this Thread
