31-05-2008, 02:32 PM #1
New Refrigerant with old evaporator
Joe consumer here. If I replace a 20+ year old R-22 home AC condenser with one with current new refrigerants will I have to replace the evaporator (only 2 years old) in the furnace? What is the most common refrigerant used in new home AC systems?
31-05-2008, 02:38 PM #2
Re: New Refrigerant with old evaporator
Probably but your best option is to ask the manufacturer.
31-05-2008, 07:41 PM #3
if the outdoor unit is not broken, why not clean the tubes en switch to R290 ? it is the best replacement for R22. just be careful, its flameble gaz.
grtz, Ice
31-05-2008, 07:43 PM #4
O yeah,
here in Belgium the newest is R410a ,
grtz , Ice
17-10-2008, 10:47 AM #5
I have a problem of refrigeration system of cold store problem is, i want set temp -20 but system not reach that point. sight glass showing system under charge if i increase gas R404a discharge pressure too high above 350psi, please suggest what i do
18-10-2008, 06:04 PM #6
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
Trane chiller tripping on "LOW EVAPORATOR REFRIGERANT TEMP"
By kaon in forum Trouble ShootingReplies: 16Last Post: 20-02-2008, 11:15 AM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM -
Refrigerant jumping evaporator
By Cary in forum Trouble ShootingReplies: 11Last Post: 30-07-2007, 11:17 PM -
Air Source Heat Pump - temp of refrigerant leaving evaporator
By anup in forum FundamentalsReplies: 3Last Post: 06-11-2006, 05:04 AM
