    Oct 2003
    Edmonton Alberta, Canada
    14
    Lightbulb Nylog as a gasket sealer
    found this forum today. looks good with a fair amount of posts. anyhoo... i love nylog for just a bout anything. i butter my toast with it. could it be used for say head gaskets on my trucks engine? MSDS sheets say that it's boiling point is 450°F and that de-polymerization occurs at 370°F. i'm asking 'cause i hate scraping gaskets. put some on copeland several years ago that just cratered and i literally just pulled the old one off. does anyone know what temps, and if they are similer to those on ref heads, that a gasoline engines run at. thanks in advance.
    Jan 2003
    Crewe, United Kingdom
    58
    723
    22
    Many manufacturers use silicone on their engines, Nylog might work on the cooler parts of the engine, but I use it mainly when fitting new "O" rings on auto A/C. To those who have not come across Nylog yet, it is a kind of never setting polymeric snot, but it is usefull for sealing auto a/c systems where alloy joints have become corroded and pitted.
    On a car engine I think that I would prefer to use a gasket!
    Karl
    Oct 2003
    14
    Unhappy on a gasket
    i guess i wasn't that clear. i mean lube the gasket just like those on a ref compressor.
    Jan 2003
    58
    723
    22
    I wouldn't want to use it on a head gasket, but cooler areas should be fine, though a bit expensive. Hermatite manufacture a non setting gasket sealer specifically for engines.
    Karl
    supremetwo's Avatar
    supremetwo Guest
    Re: Nylog as a gasket sealer
    Quote Originally Posted by Frig Pig View Post
    Where can you purchase Nylog in the UK?
    Jul 2008
    Romford
    5
    Bump for this question? Can't find a single supplier or refrigeration place that's even heard of it. All talked to me like I was stupid.
    Don't wanna have to order from the US just for a couple of bottles.
  1. Bitzer gasket
    By Renato RR in forum Fundamentals
    Last Post: 04-11-2010, 10:08 AM
  2. Blown Discharge Gasket
    By nh3wil in forum Industrial Compressors
    Last Post: 22-08-2006, 04:59 PM
  3. Scary Moments in Refrigeration.
    By homelover in forum Supermarket Refrigeration
    Last Post: 20-06-2005, 07:07 AM
  4. New system sealer
    By Ken Spragg in forum New Technologies
    Last Post: 10-11-2003, 07:46 PM
