    pjones6527's Avatar
    pjones6527 Guest
    Air Handling Unit(AHU) Efficiency
    We use an Air Handling Unit(AHU) to supply heating & cooling to our office. The current temperature/humidity setting of the unit is 22degrees/50%RH.
    I would like to increase the temperature to 27/28 degrees with reduction of chilled water usage in mind which would result in reduction of costs.
    What I am trying to find out is: If the Temperature is increased to 27/28 degrees, will the AHU be running efficiently trying to maintain the relative humidity at 50%RH or will power usage be increased for this setting. (For this example take the outside temperature to be at 25 degrees)
    Any advice on this would be much appreciated.
    Aug 2007
    Russia
    93
    14
    Re: Air Handling Unit(AHU) Efficiency
    What method of the humidification do you use?
    Feb 2007
    SIDE OF THE ROAD
    263
    12
    hi,
    a good ddc engineer is what you need, check if you are controlling off the return air or local stat watch out for solar gain on the florrs!!! check if your entalpy control,mixing box etc.. are all in order...if you are increasing setpoint i would raise chilled water set point and look to decreasing fan when dehum required and dew point for 26/27 degrees
    rgrds phil
    Oct 2001
    Nottingham UK
    5,117
    42
    With an outdoor temperature of 25 and an indoor target temperature of 27/28 you don't need chilled water cooling, you need heating!
    I'm back on the Pale
    Feb 2007
    Bedford
    38
    Temperature and humidity are in relationship higher the temperature the lower the humidity.
    Freecool
  1. Hi, ref handling and my options
    By jdunc2301 in forum Fundamentals
    Last Post: 12-04-2007, 12:32 AM
  2. Replies: 5
    Last Post: 24-07-2006, 03:28 PM
  3. gas turbine efficiency
    By Ahmed_LNG in forum Refrigerants
    Last Post: 23-04-2006, 12:50 PM
