Results 1 to 9 of 9
Thread: Herl valves
28-05-2008, 04:41 PM #1
Herl valves
Hi all,
Does anyone of you have Kv-values of the Herl valves (stopvalves T5/T6, regulating valves R, stop/check valves RUV, ...).
I do not find them in their Technical Leaflets, neither on the web site nor on the Parker websiter, neither in their Herlcalc software).
It would help a lot ...
30-05-2008, 09:53 AM #2
Re: Herl valves
Just a refreshment of my request. It seems Kv values are hard to find for Herl valves. Even our local distributor does not have this data...
Anyone please ...
30-05-2008, 12:13 PM #3
Re: Herl valves
Hello BESC,
Try calling Transmark FCX in the netherlands they are supplier of HERL.
The are situated in Waddinxveen.
Greets.
30-05-2008, 01:47 PM #4
Re: Herl valves
Hi Bart,
Thanks for the information. But since I work for a direct competitor of Herl, I fear I will not get far with them. In Belgium I have good contacts with the local dealer/distributor. But he does not (!) have the data ...
They seem to be classified (?).
Best regards.Last edited by BESC5240; 02-06-2008 at 10:05 AM. Reason: forgot the word 'not'
30-05-2008, 08:24 PM #5
Re: Herl valves
http://www.herl.de/herl/english/start_e.htm
How about sending them an e mail?
Chemi
02-06-2008, 10:01 AM #6
Re: Herl valves
Hi Chemi,
believe me, I know their site. I have searched it from top to the bottom, and backwards , and backwards again. I have their 400 page cataloque in front of me and their software on my laptop. The information just isn't their. Before I start anoying people with a question, I make sure I don't have the answer within reach ...
Like I said, I work for a direct competitor of them.
Asking them by e mail would by like if I was working for the BMW and would send an e mail to Volkswagen to ask for testing results on some of their motors.
I'd rather ask it in an informal way (to people I know working with/for Herl, anyone on this forum ?) then in direct way.
I also think it's strange they keep this kind information hidden. In contrast with all the other valve manufactorers who share this information in public.
But I'll keep on searching
Best regards
06-06-2008, 02:22 PM #7
Re: Herl valves
BESC5240,
If the pressure loss or flow calculations you want to make are not critical can you use the values from a similar valve geometry?
This method may not be exact, however the answer should be fairly close to the actual value if you had the real kv factors anyway.If all else fails, ask for help.
10-06-2008, 08:57 PM #9
Re: Herl valves
Bescie, can I do something?
Stainless steel valves
By Tycho in forum NH3Replies: 5Last Post: 05-11-2008, 02:16 PM -
Hinari and how far to open valves
By stryker in forum Air ConditioningReplies: 6Last Post: 14-04-2008, 01:47 AM -
dan foss tx valves
By fuzzy in forum Trouble ShootingReplies: 7Last Post: 02-10-2007, 01:11 PM -
ball valves leaking
By john howie in forum System OptimizationReplies: 9Last Post: 27-01-2007, 05:09 PM -
setting of hand reg valves
By ecclesk in forum IndustrialReplies: 7Last Post: 21-04-2005, 08:50 PM
