Results 1 to 1 of 1
27-05-2008, 03:37 AM #1
Atmospheric Condenser Sizing/Calculations (Simplified)
Was wondering anybody has a simplified method for an atmospheric condenser sizing or calculations. For example; say Condensing Load = 1320KW, Tc = +40degC, Refrigerant = NH3, Ambient Air Temp = +35degC, Intended Pipe SIze to be used = 2inches API Sch 40 Black Steel Pipes 5.8m per lgth.
Queries:
1. What value should we use for U (Kcal/h/m2)?
2. For area, do we use the internal area of the said pipes or the external area of the said pipes. This make a lot of different in terms of the numbers of pipes required for the given condensing load.
3. Do we need to still "spray" water over the atmospheric condenser or there is no need to do this?
4. Is ambient air temp of +35degC here in Asia a realistic assumption or it is OK to use say, +30degC. because again, materials used can be reduced substantially.
Awaits forumers comments.
Thanks,
Ivan
Superheat and Subcooling
Plate Heat Exchagers - Condenser
By Billy Ray in forum Technical DiscussionsReplies: 9Last Post: 11-05-2008, 06:16 PM -
method to design air cooled condenser
By abbasi in forum New TechnologiesReplies: 4Last Post: 12-02-2008, 08:34 AM -
Optimum condenser fan speed
By star882 in forum FundamentalsReplies: 4Last Post: 27-02-2006, 01:50 AM -
Evaporative condenser surface area
By Gonzalo Arias in forum FundamentalsReplies: 5Last Post: 06-08-2005, 11:27 PM
