Results 1 to 1 of 1
Thread: vrf- Mitsubishi heavy industries
25-05-2008, 11:57 AM #1
HI Guys,
By any chance has any of you worked on any of these vrfs.Have a couple of problems.I have achieved the technical manual but as always problems are different most of the time.One of to start with is it start to load up using obviuosly the inverter compressor first but stops on 30% load,with no errors on display.Another vrf has inverter compressor starts up,curring gradually rising to 9 A then stops,error E33.Indicating a seizure.Howcome ?It is mains reset and then restarted,does the same and then stops!
Mitsubishi Heavy Industries
By Freecool in forum Air ConditioningReplies: 6Last Post: 17-08-2007, 03:20 PM -
fault codes for mitsubishi heavy industries air con
By mal in forum Trouble ShootingReplies: 1Last Post: 21-10-2006, 06:20 PM -
Troubleshooting Mitsubishi Heavy VRV System
By Cofreth in forum Trouble ShootingReplies: 2Last Post: 29-08-2006, 05:41 PM -
Mitsubishi Heavy Industries HELP
By Bakerbj in forum Air ConditioningReplies: 10Last Post: 26-07-2006, 03:18 PM -
MITSUBISHI Heavy Industries
By coolit24 in forum Air ConditioningReplies: 8Last Post: 06-03-2006, 08:46 AM
