Results 1 to 12 of 12
Thread: Thread sealer
21-05-2008, 09:47 PM #1
Thread sealer
Hello guys, I've got a beermaster condensing unit with a fusible plug on the receiver that leaks around the threads. Can you guys recommend a good thread sealant for use on fridge gas or will plain old ptfe tape do?
Andy
21-05-2008, 09:52 PM #2
Re: Thread sealer
ptfe tape would do, other than that I have previously welded it in.
and go get a cuppa
21-05-2008, 09:55 PM #3
Re: Thread sealer
How did you weld it in without damaging the fuse?
21-05-2008, 10:03 PM #4
Re: Thread sealer
I've been using 'Trublue' made by a company called Rectorseal and sold by RPW. Its only a few quid for a 50g tube. I like it better than 'leaklock' which does the same job and is sold by NRS/climatecentre, it also used to be blue but is now in a yellow tube for some reason.
Jon
21-05-2008, 11:35 PM #5
Re: Thread sealer
good old ptfe with locktite for that extra bit of peace of mind...
Never underestimate anybody, you never know when they will make you look like an idiot!
21-05-2008, 11:51 PM #6
Re: Thread sealer
and go get a cuppa
23-05-2008, 10:54 PM #7
Re: Thread sealer
HRP didn't have anything in stock, so I ended up just using the ptfe - Worked fine.
Andy
23-05-2008, 11:16 PM #8
Re: Thread sealer
Depends on the refridgerant. PTFE will only work on R22. R407C and R134a are known to degrade the ptfe, so only loctite 55 can be used! only dowside is, it takes 24 hours to dry!
25-05-2008, 08:59 PM #9
Re: Thread sealer
Lowrider - I didn't know / even thought about the possibility of degradation with 407c. I'll find out next year during the next maintenance visit
Andy
25-05-2008, 09:07 PM #10
25-05-2008, 10:15 PM #11
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Thread sealer
Loctite 55 is cord made of Polyamide and don't need any drying.
http://www.loctite55.co.uk/oem/55/_gfx/55_EN.pdf
Did you mean Loctite 554?
http://tds.loctite.com/tds5/docs/554-EN.pdfLast edited by nike123; 25-05-2008 at 10:29 PM.
25-05-2008, 10:24 PM #12
Nylog as a gasket sealer
By Frig Pig in forum New TechnologiesReplies: 5Last Post: 22-07-2010, 03:58 PM -
Vallient gyser thread #2
By The MG Pony in forum FundamentalsReplies: 8Last Post: 27-11-2007, 12:48 AM -
New system sealer
By Ken Spragg in forum New TechnologiesReplies: 8Last Post: 10-11-2003, 07:46 PM
