Thread: Prep-Test Help
    Jun 2003
    Philadelphia, PA
    48
    48
    Prep-Test Help
    Hello,
    Everyone..know that things are starting too slow down!! Has or does anyone hold a Master Electrician License? If so can you point me in right direction as far as finding some good test prep books or programs. Any help will be appreciated..I am located in Philadelphia PA
    Thanks,
    Paul Paxson
    PAX Commercial Refrigeration
    Sep 2003
    South Yorkshire UK
    57
    Try this site, hope its of use.
    http://books.elsevier.com/
    Jun 2003
    Philadelphia, PA
    48
    48
    thank you...happy holidays
    May 2003
    Edmonton alberta Canada
    95
    21
    Re: Prep-Test Help
    Quote Originally Posted by PAX*****
    Hello,
    Thanks,
    Paul Paxson
    I did ask about RSES before check the web www.rses.org there are some good members in your area. I am past President of
    RSES Canada
    wesmax
    Wes Maxfield
    Jan 2003
    East Anglia
    1,160
    Re: Prep-Test Help
    Hi Guys,
    Sort of on the same subject but for the UK.
    1st Jan see's new regs come into play about electrical installation and people having the correct qualifications. Does anybody know what it's including. I am fairly sure you don't need to be qualified to 17th Reg standards to wire in a condensing unit or compressor buy what does it cover.
    For all of those of you in management positions, what qualifications do you look for when advertising for engineers. Is there an industry standard basic qualification for electrics or is it covered by various C&G courses
    Fatboy
    Apr 2001
    2,099
    27
    Re: Prep-Test Help
    Hi Paul.
    Nice to see you posting again............
    Im glad youre thinking of adding new strings to your bows.
    You cannot go wrong if you do, and these days its the certificate that counts.
    Your licence counts and paves the way to earn more.........
    Here in the UK, the gas guys got themselves licensed, excluded all others and guaranteed themselves top dollar rates.
    The electricians are doing the same.
    The fridge guys............any ton , **** or harry can fiddle with his gear............
    We are nowhere near to being exclusive.
    I advise, get licensed in other areas..........this way you cover yourself
    Cya
    Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
    Aug 2001
    1,046
    Re: Prep-Test Help
    Quote Originally Posted by rdocwra
    Hi Guys,
    Fatboy
    At the risk of wandering off-topic, the new regulations in the UK simply regularize a loop hole that applied to domestic electrical safety.
    What?s happening on January 1st in the UK is that new electrical work in dwellings is covered by changes to the Building Regulations 2000. Thus they come under local authority building control. You can check on the Building regulations at the web site of the Office of the Deputy Prime Minister ? Building Regulations.
    http://www.odpm.gov.uk/stellent/grou...dreg_page.hcsp
    The Regulations have approved documents that explain them:
    Approved Documents:
    http://www.odpm.gov.uk/stellent/grou...hcst?n=240&l=2
    You can get Part P on Electrical Work:
    http://www.odpm.gov.uk/stellent/grou...reg_029960.pdf
    Have a look at the AD, It explains things quite clearly and it does not apply to commercial work.
    Nothing changes in relation to the BS 7671 which apply standards to both.
    It simply means that any electrical work in dwellings have a regulatory route for formal testing. If you are a commercial concern, you are unlikely to be doing anything you were not doing before. In another area it extends the responsibility of DIYers to test new work and it may be included in surveyor?s reports at the time of sale.
    Before the days of self certification when the electrical industry was nationalized and run by regional boards, all new installations had to be tested before connection. A man in a brown coat came around with his megger and loop impedance tester.
    Hope this helps.
    ________
    BMW 003 history
  1. Pressure piping test
    By Volnei in forum Industrial
    Last Post: 03-07-2010, 10:30 PM
  2. Daikin VRV II Test Mode Failure
    By KISS KISS BANG in forum Air Conditioning
    Last Post: 30-05-2010, 08:54 PM
  3. air cooling and heating coil test
    By Lc_shi in forum Technical Speculations
    Last Post: 23-02-2006, 01:15 AM
  4. Annual Leak Test
    By Dave Finlay in forum Air Conditioning
    Last Post: 04-04-2004, 12:35 PM
  5. `skills / trade test???????
    By pagey in forum Chit Chat & Service Stories
    Last Post: 24-03-2004, 03:31 PM
