Thread: Condensor Fan Failure
19-05-2008, 08:11 AM #1
Dear All,
I am an Automotive AC Service Engineer . Started this job a month ago .
Can anyone help me in letting me know what could be the problems that I can observe on the AC System when the Condensor Fan Fails .
How Critical is the Condensor Fan for a proper functioning of the AC System ?
Best Regards,
KRK
19-05-2008, 10:29 AM #2
Re: Condensor Fan Failure
The cond fan is a very important component on a system.
If the fan fails to work correctly the heat will not be rejected and therfore the system will overheat and fail.
taz.
19-05-2008, 11:38 AM #3
You'll get HP trips whenever the vehical is stationary without a working condenser fan.
I know because my ute doesn't have one! Factory fitted ford a/c it is as well. Before next summer I'm going to have to fit a thermofan and wire it to the compressor clutch solenoid.
20-05-2008, 12:40 AM #4
No condenser fan on a mobile means driving at a minimum of 43mph (69kph) to ensure sufficient airflow through the condenser.
20-05-2008, 01:00 AM #5
Good job my old Harley hasn't got a/c then!!!
Carrier Transicold Container Problem
By Shamel in forum TransportReplies: 39Last Post: 23-01-2012, 11:23 PM -
temporary communication failure in supermarket rack controller
By racktech2008 in forum Supermarket RefrigerationReplies: 12Last Post: 27-04-2008, 09:17 AM -
defrost thermostat closed failure
By rkmoorthy in forum Trouble ShootingReplies: 2Last Post: 02-03-2008, 10:55 PM -
screw compressor failure
By aygul in forum Trouble ShootingReplies: 23Last Post: 09-12-2004, 09:09 AM -
Compressor failure...... cause
By herefishy in forum Technical SpeculationsReplies: 8Last Post: 06-12-2002, 12:15 AM
