Results 1 to 2 of 2
Thread: R134a to R407C
15-05-2008, 01:50 PM #1
R134a to R407C
I'm looking at a job where the packaged water chiller is running on R134a. The chiller has 4 off MTZ160-4 Manurope compressors fitted, running as two circuits. Air cooled condensors and 2 plate heat exchangers. Internal ciculation pump and process pump.
The ciller is being used to cool the hydraulic oil on a press. The press is fitted with a 185kW process motor and a 5.5kW recurculation motor.
We have already decided that the 2 heat exchangers fitted are too small. However there is a concern that the ciller also does not have enough capacity so I'm considering changing it to R407C.
Perameters at the moment on 134a are:
Evap Temp - 6.5'C
Condensor Temp - 50.0'C
Measured super heat - 10'C
Set point-11'C
Acutal temp - 12.6'C
DT on flow & return - 5'C
Flow rate to process - 227l/min
What sort of gain in duty could I expect from changing to R407C? Also I know I will need to change the TEV orifices, any thing else that would need to be changed?
Lots of questions I know, but any help would be great.
15-05-2008, 03:04 PM #2
Re: R134a to R407C
Those compressors have a capasity of 24,2 kW each at 6/50*C, 10K superheat and zero subcool with R134A. Power consumption 8,1 kW each.
With R407c you get 37,2 kW each at 8/52*C dew point. Power consumption 13,2 kW each.
An other alternative is R404a. Capasity 36,4 kW and power consumption 14,9 kW each at 5/50*C.
You need to increase the capasity of both the evaporator and the condensor.
What is the in/out temp of the oil at 6,5*C evaporating?Last edited by SteinarN; 15-05-2008 at 03:07 PM.
R507 in an R134a compressor: any danger?
By DaBit in forum Technical SpeculationsReplies: 30Last Post: 21-12-2009, 01:44 AM -
r134a as a substitute for r22?
By m-nelson in forum Supermarket RefrigerationReplies: 5Last Post: 24-08-2007, 11:16 PM -
Pressure Transmitter R134a Setpoints
By cooltrain in forum Technical SpeculationsReplies: 0Last Post: 28-02-2005, 10:05 AM -
Is there anything about R134a that is better than R12?
By dude in forum RefrigerantsReplies: 5Last Post: 01-03-2004, 10:59 PM -
R507 in an R134a compressor: system design
By DaBit in forum Technical SpeculationsReplies: 17Last Post: 01-05-2003, 09:25 AM
