    Jan 2002
    Austin, Texas
    716
    TEV for 3-banger chiller?
    We have been griping about the inability to apply an expansion valve in the CPU, VC, and chipset cooling applications. But in considering Bowman 1964's 3-evap single system design, I decided that if we attribute a 150w load for each evaporator (450btuh approx.), times 3 evaps = 450w (1,350 btuh) or .1125 tons.....
    Guess what.... that's right in the ballpark for a Sporlan EF-1/8 expansion valve.
    St. Louis, MO
    509
    Give or take a little. One TEV controlling 3 separate evaporators?
    Prof Sporlan
    Jan 2002
    Austin, Texas
    716
    Think of it as a multiple circuit evaporator. Perhaps a properly sized distributor would be called for, but I'd whip it together before I called the plant to spec one for me.
    The evaps will be on a common suction, therefore NOT "seperate"
    i might consider piping in series. The valve would definitely be externally equalized, because I would imagine a pretty good pressure drop through the tiny evaporator(s) circuit.
    The low pressure connections between the blocks (evaporators), merely think of as return bends on a fan coil.
    (the evaps/blocks are no more that 6" away from each other)
    OH!!!! .... Professor, I placed that order today. I was told it would be 3 to 4 weeks from the plant for my EFSE-1/8-ZP expansion valve. Could you go out on the floor, and tell the guys to put roller skates on it? LOL!!!
    May 2006
    United Kingdom
    52
    Re: TEV for 3-banger chiller?
    You could try mounting a low pressure reciever/suction accumalator on the outlet of the evapourators with a common suction which you control the superheat on?
    Mar 2005
    638
    I've seen a few folks try to run 2 or three evaps in parallel from one TXV with limited success. The problem is the ability to feed the coils correctly under all conditions. Unless you have some sort of distributir, the feed will be very problematic at best.
    Ken
  1. Dunham Bush Chiller Alarm
    By Regulator in forum Air Conditioning
    Last Post: 08-12-2010, 01:42 AM
  2. DIY aquarium chiller
    By BarraCuda in forum Technical Discussions
    Last Post: 06-10-2010, 11:02 PM
  3. York Screw Chiller How low will it go?????
    By bruceboldy in forum Industrial Compressors
    Last Post: 10-08-2007, 10:29 PM
  4. Chiller fault
    By iceman007 in forum Trouble Shooting
    Last Post: 27-06-2006, 06:15 AM
  5. Chiller Fault
    By iceman007 in forum Air Conditioning
    Last Post: 13-05-2006, 07:23 PM
