Results 1 to 12 of 12
Thread: LG Fridge problem
13-05-2008, 02:35 PM #1
LG Fridge problem
Hey guys/girls. I have a LG fridge model #GR-S642AT. The other day the front panel went blank and all that is showing is a H. I pulled the back panel off and cleaned all the dust from the little fan, turned it back on and the screen was back to normal and all seemed to be good. But after a few hours it went back to the H. Any ideas would be much appreciated. Thank-you
13-05-2008, 06:42 PM #2
Re: LG Fridge problem
http://au.lgservice.com/index_b2c.jsp
Hi Big Minge.
I guess you really need to wait for Paulh, he seems to be our white goods specialist amongst many other topics!
In the meantime if you follow the link above it will pointyou in the direction of the Oz LG site.
Where you can obtain a Owners Manual for your fridge.
Follow the Owners Manual Icon.
Cheers Grizzly.
14-05-2008, 01:46 AM #3
Thanks Grizzly. I'll see if this helps
14-05-2008, 08:37 AM #4
Not really a LG fridge specialist. I don't have many fault codes for them.
But I've never heard of a "H" by itself.
Normally it shows up two or three fault code letters.
F= fan,
So I'm going to guess you have an open circuit defrost Heater.
You'll definitely need parts, so you may as well call the LG service agents.
14-05-2008, 09:12 AM #5
Cheers for that. I thought i was gonna have to get someone out, but was hoping i didn't have to
14-05-2008, 10:09 AM #6
dunno if will help but on the LG fridges i do if on top of the appliance there is the power unit. take off cover and all error codes are list as well as wiring diagram,dunno if same were u are
14-05-2008, 11:59 AM #7
Cheers for that tonto33. It is all the same except for showing a wiring diagram and what the error codes are. *******s.
14-05-2008, 08:05 PM #8
ok must be different over there as i just take lid off and stuck on underside of lid are all the details that i need, not come across H but spoke to LG here said could be fault we defrost heater? but they not sure as they cant bring up that model number on there site..http://eic.lgservice.com
15-05-2008, 02:58 AM #9
Thanks for the help tonto33. But i think it looks like i'm gonna have to get a repair man out. As soon as i find out what it means and what the problem was i'll let you guys know
15-05-2008, 01:35 PM #10
14-02-2009, 03:46 AM #11
ANSWER TO LG .. H -FAULT-
IN behind the freezer back panel where evaperator is.
you have a sensor 2 oranges wire.and a fuse blue and brown connected together by one plug.the fuse is stuffed. replace and no more H code. fridge can not defrost with stuffed fused. so will not get cold..I think i am a genius........
22-11-2009, 12:30 PM #12
Have same LG started random beeping tonight. What fault could it be detecting? neither of the lights work.
coolinf fan problem samsung rs21 dgrs fridge freezer
By bogtrotter in forum Trouble ShootingReplies: 6Last Post: 21-03-2008, 08:45 PM -
Hotpoint Future Fridge Cooling Problem
By Stoksey in forum DomesticReplies: 10Last Post: 26-01-2008, 07:42 PM -
Frosting Over Problem In Domestic Fridge
By Leisure in forum Trouble ShootingReplies: 7Last Post: 26-08-2006, 01:52 AM -
By Leisure in forum Trouble ShootingReplies: 0Last Post: 23-07-2006, 03:52 PM
