Thread: Regarding Static Pressure
11-08-2008, 04:41 AM #1
DEAR FRIENDS,
ONCE I POSTED A THREAD REGARDING STATIC PRESSURE ONLY A FEW LIKE PETER REPLIED ME BUT STILL IAM STRUGGLING TO CALCULATE THE STATIC PRESSURE IN DUCTS EVERY TIME WHEN IAM CHECKING THE DRAWINGS I CAN SEE DIFFERENT STATIC PRESSURE FOR DIFFERENT DUCTS LIKE 450pa,150pa ETC I DONT KNOW HOW THE CONSULTANT IS CALCULATING THIS ANYBODY PLS BRIEF ME HOW TO CALCULATE THIS ATLEAST IN THIS THREAD
11-08-2008, 05:44 AM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: Regarding Static Pressure
Check this example!
11-08-2008, 06:27 AM #3
thanks for your reply mike the example you given is only for round ducts what about rectangular what about length of duct,is there any formulas to get accurate result and also it differs based on the room why nobody is replying for this thread is there any shortage for expert in ducts
11-08-2008, 07:12 AM #4
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
I taught that you want to see how it is done!
If you want to learn how to do that by your own, then you should buy some books and learn all what is needed to make proper calculation.
Or you could just buy some software to do that instead of you, but you still need to know what is important to be able to give right data to software.
Some links:
http://www.acca.org/design/
http://www.acca.org/store/product.php?pid=91
11-08-2008, 07:27 AM #5
I Dont Want To Depend On Software I Want To Improve My Own Knowledge If You Have Any Pdf File Based On This Pls Send To Me Thanks
11-08-2008, 11:48 PM #6
In that case then you must spend some money on teaching yourself through text books and training courses.
The knowledge comes from learning; round ducts or square ducts require similar calculations. The area of the duct is involved more than the shape.
A quick fix for designing things is not possible. You need to learn, practice, learn some more and practice some more; only then will you understand your problems.Brian - Newton Abbot, Devon, UK
12-08-2008, 01:31 AM #7
dear brian iam eager to learn but tell me the book, which book i have to refer in this issue iam just asking the method to calculate why nobody understanding that at present iam working in singapore here i searched in library i cant find anything related to HVAC
12-08-2008, 01:30 PM #8
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
12-08-2008, 11:31 PM #9
Links work fine Nike.
Other books etc available here..
http://www.constructionbook.com/hvac-ducts/
All done with the power of Google
Also from Google, training courses in Singapore......
https://gpxsvr3.np.edu.sg/apps5/cpd/...D?OpendocumentLast edited by Brian_UK; 12-08-2008 at 11:37 PM.
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
Fan Static Pressure
By Samarjit Sen in forum FundamentalsReplies: 5Last Post: 27-09-2007, 02:48 AM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM -
Fan Static Pressure
By watana in forum Air ConditioningReplies: 3Last Post: 05-10-2003, 06:43 AM
