Results 1 to 2 of 2
Thread: McQuay chiller tripping
09-05-2008, 10:01 AM #1
hai
My McQuay chiller, model AGR 075, is showing alarm L.P.failure.I closed L.P.Switch and checked digital input on board. All correct. Although display shows L.P alarm! Can anyone please help me? Has anybody the wiring diagram of this same chiller?
09-05-2008, 11:19 AM #2
Re: McQuay chiller tripping
Moideen I will email the IOM that I have, for that model.
You don't say whether you have "manually reset" the alarm function.
The chiller will not run on certain alarm conditions unless a "manual reset is carried out"
To do so you have to access the Controller (page 75 for McQuay Microtech)
If you have a Johnson Controls UNT Controller then that is covered in the manual also.
There are also wiring diagrams for the chiller with both controller types covered.
I hope this helps?
McQuay chiller
By paulh in forum IndustrialReplies: 16Last Post: 21-12-2011, 02:27 PM -
process chiller help
By talon771 in forum IndustrialReplies: 8Last Post: 12-01-2011, 08:42 PM -
mcquay centrifugal chiller 063 compressor
By maico in forum Trouble ShootingReplies: 4Last Post: 22-11-2010, 06:40 PM -
Trane chiller tripping on "LOW EVAPORATOR REFRIGERANT TEMP"
By kaon in forum Trouble ShootingReplies: 16Last Post: 20-02-2008, 11:15 AM -
Mcquay PES Flooded Water Cooled Screw Chiller
By Brian in forum Technical SpeculationsReplies: 4Last Post: 05-07-2006, 09:43 PM
