02-08-2008, 05:23 PM #1
Re: running the oil pump to check oil level
on a centrif the oil cicuit is not 100 % tight some oil will be discharged into the ref circuit with just the pump running so if you have a job where the bas is starting/stopping the chiller alot you may not have enough run time for the oil recovery system to return oil to the sump.
frostles heat pump
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 09:27 PM -
Air conditioning maintenance procedure
By Andy T in forum Air ConditioningReplies: 12Last Post: 27-05-2006, 06:57 PM -
LG heat pump condensor fans slow running
By Mickvee in forum Trouble ShootingReplies: 12Last Post: 22-11-2005, 08:17 AM
