Results 1 to 8 of 8
    Mar 2008
    Ireland
    9
    Question Climaveneta fault codes
    Has anybody got list of climaveneta fault codes for HRAT (E06,E22) cant seem to find on the net, thanks
    Apr 2006
    Torquay
    59
    130
    Re: Climaveneta fault codes
    Hello Kevin(us Kev's should stick together), if its a cvm 2, E06 is ST2 probe malfunction (connections 3&4 on board. E22 is circuit 2 low pressure, sounds like probe at evap outlet water temp isn't working and the comp is continuing to run on down and tripping LP.Hope this helps, let us know how it goes. Kev.
    Somerset
    69
    4,698
    Quote Originally Posted by 1torr View Post
    Hi Kevin.
    Good to see you back!
    How's tricks.
    PM me if you wish?
    Mar 2008
    Ireland
    9
    Thanks 1torr that sounds right, back on site tomorrow will check it out
    conor1967's Avatar
    conor1967 Guest
    hi, working on a climavenete chiller today.its a be/srat and fault code e103 is coming up. this anyone know how to clear thism thanks
    bill234's Avatar
    bill234 Guest
    air conditioning is the better solution in all aspects of air condition maintenance and repair
    Somerset
    69
    4,698
    Re: Air Conditioning Florida
    Quote Originally Posted by bill234 View Post
    CHEAP SHOT Bill!
    Seeing as the company you recommend forms the basis of your email address.
    I can only assume that these last 2 posts are a attempt at Self promotion?
    Please restrict your enthusiasm to Helping others as the rest of us do!
    Aug 2008
    London
    69
    59
    ...E103 code indicates the compressor thermal overload protection, possible cause being the compressor motor overheating...
  1. carrier fault codes
    By richelli in forum Trouble Shooting
    Last Post: 18-06-2010, 07:35 AM
  2. Daikin fault codes
    By Markie in forum Air Conditioning
    Last Post: 13-01-2009, 01:58 AM
  3. Chigo Cpa-09co Fault Codes? E4?
    By chigosimon in forum Trouble Shooting
    Last Post: 24-11-2007, 12:46 AM
  4. standardisation of fault codes?
    By kelvin kline in forum Air Conditioning
    Last Post: 10-10-2007, 12:30 AM
  5. MHI, Sanyo & Fuijitsu Complete Fault Codes
    By aeb200 in forum Air Conditioning
    Last Post: 16-11-2005, 01:11 PM
