    3,853
    Welding refrigerant bottles
    I have a small recovery bottle and two of the three welds holding the lifting hand have broken. Looking at the welds i think one of them wasn't doing anything in the first place and the handle has been moving about and hence the second weld has failed.
    What do you think to getting it welded back on?
    Or is it not worth the risk with it being a pressure vessel?
    I hate throwing things away that can be fixed, my metal tool box for example has been welded up a couple of times, new catches put on, new handle. Its just about due its third refit as it has a couple of fatigue cracks developing
    Jon
    Last edited by monkey spanners; 07-05-2008 at 08:10 PM. Reason: You'll just have to wonder...
    Split Croatia
    6,151
    Re: Welding refrigerant bottles
    Jon
    Weld it, and pressure test it with water.
    Last edited by nike123; 09-05-2008 at 06:49 AM. Reason: removed test with nitrogen
    Feb 2007
    2,473
    My first job after Uni was building steam boilers.
    The babies there were pressure rated up to 30 Bar and we always welded feets/handles/lugs on to the original vessels.
    (Mind you, due to H&S legislations we had to pressure test with water, in a reinforced concrete basin afterwards...)
    Nov 2006
    63
    392
    No problem with welding as long as you get a test certificate from an authorised testing house. Personally for the sake of thirty quid is it worth it taking the hassle if anything goes wrong.
    Ian
    Mar 2008
    Ireland
    9
    Weld away have done same job just remove hand valve so no presure can build up when welding, and presure test with nitrogen.
    Just a word of caution with your pressure testing.
    I know that we PT on systems up to high pressures but, on the whole, they have already been tested at the factory etc.
    Please don't stand next to the bottle while you're doing it, just in case. Steel ruptures in a different fashion to copper.
    3,853
    I think its going in the bin, as pooh says not worth it for a few notes.
    I've never much liked the idea behind pressure testing, basically lets see if it goes BANG! while i'm stood next to it, always seems to me a bit like a plumber checking for gas leaks with a match, BANG! "found one"
    Cheers Jon
    Croatia
    68
    2,261
    Hi, monkey spanners
    Cheers Jon
    .... you can do it with old clean oil or water - hydraulic test and NO BANG .... safety and the ONLY way to do it ... DO NOT USE ANY GAS FOR PRESSURE TEST OF VESSEL, EVER, PLEASE here I mean about strength test, for leak test it is ok
    Best regards, Josip
    3,853
    That Araldite is wonderful stuff....
    Oct 2003
    5,630
    Hi, monkey spanners .... you can do it with old clean oil or water - hydraulic test and NO BANG .... safety and the ONLY way to do it ... DO NOT USE ANY GAS FOR PRESSURE TEST OF VESSEL, EVER, PLEASE here I mean about strength test, for leak test it is ok
    Best regards, Josip
    Was going to make the same comment Josip. If you pressurize with gas and it cracks, then you will have a serious explosion.
    Not with a liquid because it doesn't expand.
    Sep 2005
    42
    191
    a bit like a plumber checking for gas leaks with a match, BANG! "found one"Cheers Jon
    there's another way to do it ?
    (seriously tho... I do that all the time.....)
  1. Suction Line Welding
    By Brian G in forum Fundamentals
    Last Post: 14-05-2007, 07:41 AM
  2. Bad welding... hate it
    By Tycho in forum Chit Chat & Service Stories
    Last Post: 28-02-2007, 10:27 PM
  3. welding copper pipes
    By kpapa in forum Tools and Calculators
    Last Post: 25-09-2006, 10:12 PM
  4. welding copper
    By kpapa in forum Trouble Shooting
    Last Post: 02-09-2006, 09:55 AM
  5. Disposable bottles what a waste
    By grabber01 in forum Refrigerants
    Last Post: 21-02-2004, 12:17 PM
