Results 1 to 8 of 8
Thread: super heat
    moideen's Avatar
    moideen is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2008
    u.a.e
    49
    412
    23
    Question super heat
    Hi to everybody
    I want to know the superheat settings of low temperature applications. Is this settings same to the medium temperature applications?
    Oct 2006
    1,843
    21
    Re: super heat
    yes superheat is the same.
    The aplication may change but superheat will be around 6 degrees.
    Superheat is a measurement of actual refrigerant temp in the suction line above saturation temp of the boiling liquid in the evap (direct expansion only).
    taz.
    Split Croatia
    57
    6,151
    36
    Re: super heat
    Are you talking about compressor or evaporator superheat?
    moideen's Avatar
    Apr 2008
    u.a.e
    49
    412
    23
    Re: super heat
    i am talking about txv superheat.
    Aug 2005
    5,302
    Re: super heat
    Quote Originally Posted by taz24
    I agree with the underlined section above, but why only direct expansion taz?????
    Feb 2008
    Las Vegas, NV
    67
    330
    Re: super heat
    Quote Originally Posted by moideen View Post
    Hi to everybody
    moideen,
    The operating SH setting at the evaporator for a refrigeration system depends on the temperature difference between the refrigerant and the medium being cooled.
    With that said here are some rule of thumbs, in degrees F.
    High temp: 8 - 12
    Medium temp: 6 - 8 F
    Low Temp: 4 - 6 F
    Powell
    Nov 2006
    63
    392
    Re: super heat
    Powell
    no disrespect but what has the medium being cooled got to do with superheat. As far as I have always thought superheat is as described by Taz24 at the beginning of this thread.
    Ian
    Somerset
    69
    4,697
    Re: super heat
    Quote Originally Posted by Pooh View Post
    Powell
    Ian
    Ouch Pooh!
    That smarts! Have you been eating the Marmite Sandwiches again?
  1. Capacity control
    By sparrow in forum Training
    Last Post: 18-01-2010, 07:49 PM
  2. Replies: 5
    Last Post: 14-09-2009, 07:33 AM
  3. frostles heat pump
  4. Help Super Heat / Subcool?
    By 2aces in forum Air Conditioning
    Last Post: 12-11-2007, 11:28 PM
  5. super heat effect
    By jamaladwani in forum Fundamentals
    Last Post: 04-11-2006, 02:03 PM
