Thread: co2 control strategy
04-05-2008, 09:43 AM #1
There are following questions about the CO2 Booster system control.Thanks for some information about the CO2 transcritical system control.
1. AS for the transcritical system, how to determine the optermal outlet pressure of gas cooler, which has close relation with the COP?
2. How to design the capacity control of compressors. can the suction pressure decide the on-off of compressors? how to control the on-off of MT and LT compressors?
3. how to control the opening of electrical expension valve for the evaporation?
Best Regards
04-05-2008, 05:50 PM #2
Re: co2 control strategy
I think you are confusing a transcritical cycle with a two stage subcritical booster cycle. If you are really looking for a transcritical double stage, then have a look here http://www.sciencedirect.com/science...25b0fbbb71d811
05-05-2008, 07:00 PM #3
yes, i am looking for the optimal control method of transcritical double stage cycle. the first expansion valve after the gas cooler reduces the pressure from 110bar to 40bar. after expansion, the CO2 is the mixture of liquid and gas. this point(40bar) has close relation with the system performance. normally, this valve use the PID controller. so how to determine the PID constants to ensure the high system performance and steady pressure conditions are what i want to discuss.
by the way,where can i download this paper?
Airwell Florida Inverter Air Condition - in need of help
By AndY1 in forum Air ConditioningReplies: 21Last Post: 05-07-2008, 10:48 AM -
Frick Quantum LX Compressor control panel: Capacity Control Screen
By screw_geek in forum Industrial CompressorsReplies: 17Last Post: 15-06-2008, 06:47 AM -
Control scenario
By Mike Hopkins in forum Technical DiscussionsReplies: 5Last Post: 14-09-2007, 11:25 AM -
Searle cellar cooler control problem
By iceman007 in forum ElectricalReplies: 6Last Post: 06-07-2004, 08:57 PM -
New Capacity Control Solution
By embrown in forum New TechnologiesReplies: 19Last Post: 30-12-2003, 01:33 PM
