02-05-2008, 07:12 AM #1
How to design -35deg c chlling plant.
Help me Designing for - 35 deg c chilling plant , For 60 kw
i am using Bitzer semi hermetic compressor model 6G.30.2y or 6F-50.2
Gas -R502, What are the precautions should i take ,what are accessories i Required .
02-05-2008, 08:43 PM #2
Re: How to design -35deg c chlling plant.
What are you chilling, air or liquid?
Precautions are the usual ones to protect the compressor from damage.
Accessories, well it depends on what you want or how much you want to spent.Brian - Newton Abbot, Devon, UK
06-05-2008, 10:57 AM #3
Check out oil retur issues with r502 at temps and seperation. Just a thought
06-05-2008, 02:17 PM #4
Dear sreenivasarao,
You better choose 6F-50.2.It will be a good solution.
Why you choose R-502
Rgds,
TJK
07-05-2008, 08:07 PM #5
I am using this system for liquid [Glycol]cooling.
Should I keep ,Liquid Receiver for this System.If yes What will be the capacity
How much Capacity ,heat exchanger and condenser ,should i take.
Which Expansion valve should i use .
Which gas is advisable.
Thank you.
08-05-2008, 06:53 PM #6
i personally find that if that compressor is able with NH3, go for it. among so many designs I did, NH3 is the easiest to handle. Some simple PLC controllers into the main control panel and you get a fully automated plant with defrosting feature and safety cut out. Since you are cooling glycol, best is use NH3, and if you still have a design of your liquid receiver, mind sending it to me, I can check if it is suitable to use it. Expansion valves? well what kind of system are u having? DX,(TEA) Pump(SV4 + pump vessel + either REG) and thermosyphon(REG). All valves recommended are from danfoss and to be use only on the liquid line. For more features look into your suction. They are crucial too.
10-05-2008, 10:43 AM #7
The Bitzer (or any other make) semi hermetic compressors are not suitable for use with ammonia. The best option for this application is to use R-404a refrigerant.
Actually for an application like this would it not be advisable to consult a person with previous experience in designing such systems?
Design, engineering and execution guides
By Josip in forum Tools and CalculatorsReplies: 6Last Post: 27-02-2009, 01:47 AM -
What design factors decides power comsumption
By kln in forum DomesticReplies: 3Last Post: 28-01-2008, 08:29 PM -
Efficient Water-Source Condenser Design?
By Enginerd in forum FundamentalsReplies: 4Last Post: 28-05-2007, 05:11 AM -
Replacement fo CO2 Bulk Tank refrigeration unit
By pabs_ref in forum CO2Replies: 31Last Post: 28-11-2006, 10:32 PM
