Thread: Mitsubishi compressor
30-04-2008, 04:46 PM #1
Hi guys, does anyone know what is the model number for a compressor that goes into a Mitsubishi puh-p5ygaa ?
Thanks in advance.
Chillin
and go get a cuppa
30-04-2008, 09:51 PM #2
Re: Mitsubishi compressor
Hi Chillin
According to the Mitsi book it is a ZR61KCE-TFD.
Do you want the Tech Manual emailed over? (PM me your email if you do)Brian - Newton Abbot, Devon, UK
30-04-2008, 09:58 PM #3
Would it be cheaper to get one from NRS/HRP than Mitsubishi?
30-04-2008, 11:23 PM #4
Thanks Brian, that would be great.
PM sent.
and go get a cuppa
30-04-2008, 11:24 PM #5
@monkey spanners, it probably would. Would that make it a different model number?
and go get a cuppa
30-04-2008, 11:47 PM #6
Don't know for sure But i fitted a replacement mitsi compressor a couple of months ago that another engineer had diagnosed and was a bit surprised to see a copeland scroll in the box from mitsubishi.
If the model numbers are the same i would think it would fit, the one i fitted also had a new compressor wiring lead as they have changed from push on crimps to loopy crimps on some models, which i didn't need, not a major problem to get over if you do though.
Just had a quick look in Nrs/climate center book and they list a ZR61KCE TFD 522 which has braze in stubs, no oil sight glass and no oil level connection, R407C, 3ph, 5hp. part no. 682460. Its also in the HRP book about 400 notes cheaper so it may be worth phoning both and see who will give the best price.
JonLast edited by monkey spanners; 30-04-2008 at 11:50 PM.
30-04-2008, 11:49 PM #7
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 09:27 PM -
Mitsubishi compressor lock
By marc5180 in forum Air ConditioningReplies: 29Last Post: 08-10-2007, 05:48 PM -
Tech info or direction to for data Mitsubishi RR120 220/240v rotary compressor
By eskimo2 in forum Technical SpeculationsReplies: 4Last Post: 04-01-2005, 04:04 AM -
Compressor pumping efficiency
By shogun7 in forum FundamentalsReplies: 0Last Post: 25-02-2004, 10:50 PM
