Results 1 to 2 of 2
Thread: Wiring diagram
29-04-2008, 01:12 PM #1
Wiring diagram
We have a roof top air conditioning unit with the following specification:
Mark: York
Model: RTH-25-B E 1 |662052583 |01008892009
Max pres.: 31bars
Indoor heat exchanger : 21.7 kw
Max testing pres. : 31bars
Fereon: R22 5.9kg
Operating weight: 355kg
3 phase 400 volt 50hz 11.1kw 44IP
The circuit board ref. is CT 1013 B made in spain
Could you please provide us with a wiring diagram for connecting the board with the internal thermostat.Last edited by plumtech; 29-04-2008 at 01:16 PM.
29-04-2008, 02:21 PM #2
Re: Wiring diagram
Plumbtech.
I have attached 3 pdf pages from a rth manual. I hope they are of some use?
They are not an exact model match but it is the best I can do from my outdated files.
Hopefully if necessary 1 of the newer Guys that work for York can Help? Maybe Barte??
I have also added another 2 that may be of use?
GrizzlyLast edited by Grizzly; 29-04-2008 at 05:24 PM.
30GK carrier chiller wiring diagram
By ash_sabi2006 in forum ElectricalReplies: 6Last Post: 20-05-2010, 04:26 PM -
30 GB wiring diagram
By Jai in forum Air ConditioningReplies: 4Last Post: 17-07-2008, 11:54 AM -
Wiring diagram for fridge truck???
By zzvaszz in forum TransportReplies: 2Last Post: 04-03-2008, 11:13 PM -
Wiring diagram
By flashvert in forum Technical SpeculationsReplies: 1Last Post: 21-12-2007, 01:01 AM -
Thermo King v? 00 MAX Tc Wiring Diagram
By Chris2005 in forum TransportReplies: 3Last Post: 01-02-2006, 09:01 AM
