Results 1 to 13 of 13
    Jan 2008
    Australia
    71
    Mycom F62WB Compressor
    Hi guys,
    Hope someone may be able to help with some info on the following compressor.
    Make : Mycom
    Model: F62WB
    Refriegrant: R22
    Rpm: 1400
    Require capacity mainly.
    Thanks in advance.
    dsp
    Aug 2007
    Adelaide Australia
    70
    562
    Re: Mycom F62WB Compressor
    Hi dsp
    Best thing is to contact Mycom in Sydney and ask for Clive, I am pretty sure he will be able to help you.
    Paul
    Jan 2008
    Australia
    71
    Thanks Paul
    Ill give him a go.
    dsp
    Nov 2007
    Jakarta
    75
    11
    Hi dsp,
    from Mycom performance data i got as follows :
    MYCOM F62WB @Te-40'C/Tc+35'C and speed 1200 rpm is 91,400 kcal/hr with motor 90 kw.
    And for model with WB max speed is 1,200 rpm.
    For model F62WA you can run with 1,400 rpm. Cooling capacity at Te-40'C/Tc+35'C is 41,600 kcal/hr w/ motor 55kW
    Jan 2008
    Australia
    71
    Thanks heaps Maguro!!!
    asep kurniawan's Avatar
    asep kurniawan Guest
    Hi dsp
    For capacity should be know what Te and Tc, so we can help you.
    malaysia
    159
    hi dsp,
    i learn from our local mycom office that most of their published doc has Tc in +35c.
    2ndly, the comp can be either direct drive or belt drive. the rpm will be different.
    but, i learn in australia there few mycom related companies have such info. again, you gain some & sacrifice some.
    hendry, on wesak day holiday.
    Hendry
    "What uncertainty means to you, and you only?"
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, dsp
    Quote Originally Posted by dsp View Post
    Hi guys,
    Make : Mycom
    Model: F62WB
    Refriegrant: R22
    Rpm: 1400
    Thanks in advance.
    dsp
    Maybe this will be of some help .... capacity for piston compressors
    Best regards, Josip
    3,355
    josip, your chart looks incorrect to my information.
    I see a mycom 8WB R22 1200RPM AT 765M3/HR
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, RANGER1
    yes, chart can be incorrect, but it is not mine ... belongs to Mycom
    Best regards, Josip
    Jan 2008
    West Coast British Columbia
    106
    If you are running this poor thing at 1400 that is 200RPM over stated Max
    Here is a basic run at 1200RPM
    DATE 07-02-2008
    REFRIGERANT AMMONIA
    MODEL N62WB
    CAPACITY [kW] 325.8
    CAPACITY [TR] 92.6
    ABSORBED POWER [kW] 85.4
    SPEED [Rpm] 1200
    LOAD [%] 100
    CONDENSING TEMP. [degC] 32.2
    EVAPORATIVE TEMP. [degC] -12.2
    SUCTION SUPERHEAT [degC] 0.00
    INTERMED SUPERHEAT [degC] 0.00
    LIQUID APPROACH TEMP. [degC] 5.00
    LIQUID SUBCOOLING [degC] 5.00
    SUCTION TEMP.(1ST) [degC] -12.2
    SUCTION PRES. [MPaA] 0.266
    DISCHARGE PRES. [MPaA] 1.24
    SUCTION PRES.LOSS [MPaA] 0.000
    DISCHARGE PRES.LOSS [MPaA] 0.000
    SWEPT VOLUME(2ND) [m3/h] 191
    SWEPT VOLUME(1ST) [m3/h] 573
    INTERMED TEMP. [degC] 21.9
    SUCTION TEMP.(2ND) [degC] 21.9
    DISCHARGE TEMP(2ND) [degC] 53.9
    DISCHARGE TEMP(1ST) [degC] 89.3
    INTERMED PRES. [MPaA] 0.913
    REFRIG. FLOW RATE(2ND) [m3/h] 143
    REFRIG. FLOW RATE(INT.) [m3/h] 22.3
    REFRIG. FLOW RATE(1ST) [m3/h] 477
    REFRIG. FLOW RATE(2ND) [Kg/h] 1203
    REFRIG. FLOW RATE(INT.) [Kg/h] 155.9
    REFRIG. FLOW RATE(1ST) [Kg/h] 1047
    OIL HEAT REJECTION [kW] 4.00
    INTERMED HEAT REJECTION [kW] 50.0
    JACKET HEAT REJECTION [kW] 14.0
    COP [-] 3.82
    --- SUPERHEAT in not counted in refrigeration capacity ---
    --- WITH WATERCOOLED OIL COOLER ---
    --- WITH LIQUID SUBCOOLER ---
    REFRIG. FLOW RATE [m3/h] 0.18
    REFRIG. FLOW RATE [Kg/h] 1.27
    HEAT REJECTION [kW] 0.41
    --- WITH INTERMED. GAS-COOLER ---
    REFRIG. FLOW RATE [m3/h] 22.1
    REFRIG. FLOW RATE [Kg/h] 154.6
    HEAT REJECTION [kW] 49.6
    --- WITHOUT SIDE LOAD EVAPORATOR ---
    If Clive has not replied just post the actual run conditions and I will repost the chart.
    Hey Josip that Chart looks off I would not go by it, you can always ask a Mycom rep to do a run any any machine.
    Iceman_400
    Refrigeration is not just cool, it is my life.
    Nov 2007
    India
    74
    Dear Ice man the guy is looking for ***** compressor and u had posted the details of compressor with ammonia.
    Please see the attachment.
    raj
    Attached Files Attached Files
    Jan 2008
    106
    Awesome looks like you got the answers you needed.
  1. Testing Inverters
    By fridge doctor in forum Air Conditioning
    Last Post: 15-06-2011, 06:52 AM
  2. Compressor loading, cooling, and range of operation.
  3. SL/SB-400 Pump Down Procedures
    By absolute-zero in forum Transport
    Last Post: 29-01-2008, 09:27 PM
  4. Replies: 7
    Last Post: 13-12-2007, 06:31 PM
  5. Compressor pumping efficiency
    Last Post: 25-02-2004, 10:50 PM
