Results 1 to 32 of 32
    Apr 2006
    stafford
    42
    985
    THE RE RULES OF THUMB,HINTS,TIPS and TRICKS
    Ok go with me on this one, RE has a massive following and many many members that all bring there own input to the form, so could we not create our own eBook contributed by the members for the members?
    Taking the best rules of thumb, hints, tips and tricks and collating them all?
    Every member that contributes gets the book and fill it with all the info we have scribbled on bits of paper in the van e.g sizing rules of thumb, condensate water produced per KW of cooling, air changing rules of thumb ect ect
    i am no computer whizz but would be willing to put my time to the project
    Good idea bad idea?
    OVER TO YOU GUYS
    Paul
    "KEEP IT COOL"
    Mar 2008
    stoke on trent
    8
    Re: THE RE RULES OF THUMB,HINTS,TIPS and TRICKS
    excellent idea
    Northants
    292
    Yeah sounds good
    May 2006
    aberdeen
    125
    Sounds good, Count me in,,
    Jan 2008
    Kent UK
    49
    515
    wonderful idea but i expect there would be a lot of different opinions on certain practices,but i bet it would be good.
    If it ain't broke, it doesn't have enough features yet.
    Damo
    Jan 2001
    Fife, Scotland.
    66
    1,199
    2
    might be doable when the site gets upgraded
    <img src=http://www.refrigeration-engineer.com/forums/image.php?type=sigpic&userid=1&dateline=1296159097 border=0 alt= />
    Apr 2006
    stafford
    42
    985
    Quote Originally Posted by WebRam View Post
    the boss has spoken so its up to us
    Paul
    "KEEP IT COOL"
    India
    695
    I am in too. We had a similar book mostly on AC etc. We need to have a similar compilation on Refrigeration.
    Split Croatia
    6,175
    I think that before anything, we need to establish origin of "Rule of thumb" term.
    Before thermometers were invented, brewers would dip a thumb or finger into the mix to find the right temperature for adding yeast. Too cold, and the yeast wouldn't grow. Too hot, and the yeast would die. This thumb in the beer is where "rule of thumb" comes from.
    A am for this in part of hints, tips and tricks but when it is rule of thumb in question, I prefer measuring and calculations.
    Apr 2006
    stafford
    42
    985
    rule of thumb:
    –noun
    1. a general or approximate principle, procedure, or rule based on experience or practice, as opposed to a specific, scientific calculation or estimate.
    2. a rough, practical method of procedure
    To clarify:
    I am after/asking the members of RE if creating a EBook of handy, hints, tips and good working practises would be of interests
    Paul
    "KEEP IT COOL"
    Dec 2006
    Mansfield
    232
    Well put over superswill.
    PP
    May 2008
    ireland
    42
    Just found this thread. sounds like a good idea.
    Anybody want to start the ball rolling?
    Apr 2006
    stafford
    42
    985
    iam up for it
    Paul
    "KEEP IT COOL"
    4,758
    Rock Hard and baked on Gaskets.
    Prior to removal, say just as you remove the covers, take a rag and dip it in some of the oil that's ALLWAYS around and wipe the gaskets with the oily rag.
    WHEN YOU COME TO REMOVE THE GASKETS.
    THEY WILL PRACTICALLY FALL OFF!
    TRY IT!!
    May 2008
    ireland
    42
    TRY IT!!
    After loosening bolts, I find that tapping both sides of fllange or fitting, fairly heavy with a hammer also works well
    4,758
    Quote Originally Posted by cmac View Post
    Hi cmac.
    Sorry I mislead you a bit there.
    I mean once the covers are off and you are left with those stubborn bits that don't want to come off!
    Cheers Grizzly
    sabyashachibasu's Avatar
    sabyashachibasu Guest
    Thats cool.Pleas count me as i am a new
    Oct 2006
    1,847
    When working in freezers if the hairs in your nose freeze up it IS cold enough.
    Touching your wet finger to the frozen pipe may let you know if it is below freezeing but don't lick the pipe.
    RULE OF TEN.
    The ten degree rule.
    The liquid in the evap boils 10 degrees lower than the air off and the air off is 10 degrees lower than the air on. The air off a cond is 10 degrees higher than the air on and the vapour condenses in the cond 10 degrees higher than the air off.
    Airflow can be tested by the back of the hand but direction on low velocity air can be hard to prove so hold a thin piece of paper in the air and see which way it moves.
    When takeing a compressor to pieces as you remove a cover or a cylinder head put all the bolts and fittings for that individual piece inside the cylinder head or cover.Then you can keep them all together and you will know which bits go where when rebuilding.
    When rebuilding the compressor always throw a spare bolt in the sump. It gives the next engineer somthing to think about ONLY JOKEING....
    Cheers taz.
    May 2008
    Northern NSW, Australia
    56
    33
    When entering an office full of hot/cold ladies,
    firstly goto the closest plant room and tap your spanner around for a minute.
    Then walk around with your thermometer asking if they feel better.
    Must be the warm fuzzy feeling of a nice fridgy that they needed.
    Doesn't work all the time...
    Oct 2006
    1,847
    Quote Originally Posted by Jadeair View Post
    So so true.
    I agree and the other one is always make sure the plant room / engine room looks clean and tidy.
    You may be the worst engineer in the world but if the customer sees you cleaning all the oil and polishing all the brass he will love you forever
    taz.
    4,758
    Quote Originally Posted by taz24 View Post
    Cheers taz.
    I actually had a colleague who rebuilt a large Halls recip and whilst clearing up..
    Complained that his torch (flash light) was missing.
    Then noticed that there was a glow from within the compressor sump, (seen through the sight glass).
    Yes! He had replaced the sump cover but forgot to remove the torch he had been using to inspect the big ends with!!!!!
    We still laugh about tha one nowadays.
    Oct 2006
    1,847
    Its funny the things we do and that the manager or customer should never know about
    Did he wait till the batteries ran flat and then said goodbye to his trusty old torch as the light flickered one last time or did he do the right thing and jump right in to save his old companion
    Cheers taz.
  23. #23
    4,758
    Cheers taz.
    Yes!
    He saw the light!
    And retrieved it. (After all it was an "Ever Ready".)
    Grizzly.
  24. #24
    Jun 2005
    Lancs
    61
    Myself and a collegue once rigged up a bog standard room thermostat in a large high street store and ran a flex up to the ceiling and poked it through the plaster and told the ladies in the vicinity that they now had total control of the temperatures around them using said stat ....... they were over the moon ........ naturally the stat was not connected
  25. #25
    Jun 2005
    Lancs
    61
    However as a rule of thumb I would be interested to know how long one should conduct a pressure / leakage check for, on a system that has been found to have a leak(s) should a leak be found and repaired. I have checked our governing bodies websites and the only clue I have is ..... " a suitable length of time should pass at the relevant pressure for the refrigerant in use " . My point is what does one class as a suitable length of time ?
  26. #26
    Mar 2010
    India
    101
    I think this thread should be sticky or display at the front page of RE so that everyone can see this thread & give reply from their great experiences
    I am trying to collect information at one place if it is wrong please correct it
    Kindly share the knowledge for our RE
    AIR CONDITIONING
    Thumb rules will always get you in trouble. Always reminding that thumb rule is for checking only
    Ac size
    Thumb rule vary according to country environment
    Volume of room in cubic feet multiplied by five gives the cooling capacity required in BTU'S
    Floor area x 125w/m2 to give you a high end kw rating.
    Room 13m x 10mx 3m
    13m x 10m = 130m2
    130m2 x 125w/m2 = 16.25kw
    Gymnasiums = 300w/m2
    Server Rooms = 400w/m2
    Cooling load estimation –
    150 W/m2 for ordinary room
    190 W/m2 for computer room
    12,000 BTU,s = 1Ton Refrigeration & 1TR = roughly 3.5 KW
    Compressor:
    The compressor should start no more than 6 times per hour
    Indoor & Outdoor
    Indoor fed 9, 12 and 18000 Btu. & outdoor fed 24K always
    Pressure:
    For R22 condensing pressure should be 19K to 22K above ambient temp equivalent pressure (air-cooled)
    Cooling output:
    (air on °C - air off °C) x air vol m³/sec x 1.2 (density of air) = kW
    Air flow:
    The amount of air flowing depends on the sensible cooling load of the space.
    400 cfm per ton is a good
    The exact outside air temperature below which the unit needs regular defrost at 7 deg C is an approximate
    RULE OF THUMB
    http://www.daikinaltherma.com:8080//SpaceAirSite/index_SA.jsp?mt=991&taxonomy_id=991&lang=en&site=991
    http://www.daikinaltherma.com:8080//SpaceAirSite/index_SA.jsp?mt=992&taxonomy_id=992&lang=en&site=992
    http://www.daikinaltherma.com:8080//SpaceAirSite/index_SA.jsp?mt=993&taxonomy_id=993&lang=en&site=993
    http://www.daikinaltherma.com:8080//SpaceAirSite/index_SA.jsp?mt=994&taxonomy_id=994&lang=en&site=994
    http://www.daikinaltherma.com:8080//SpaceAirSite/index_SA.jsp?mt=995&taxonomy_id=995&lang=en&site=995
  27. #27
    Jul 2010
    NTH.QLD Australia
    1,762
    32
    How about 65 btu/sq ft for home a/c where ambient can exceed 32c and insulation installed in the roof.
  28. #28
    May 2009
    aust
    14
    when i did my time in nz an old engineer welded abit of 3/8 cu tube to a bit of 1/2 cu tube and fitted flare nuts (welded)to the pipe the txv was buggered but he set the super heat with 2 *12 inch shifters till the morning. the copper acted as a metering devise and i was left to tension the nuts if the liquid came back.funny but true and worked .cheap labour back then
  29. #29
    May 2009
    aust
    14
    50/100 watts m2
  30. #30
    Sep 2008
    429
    A get out of trouble on a Saturday afternoon idea when there`s vibration loosening nuts. Cut a slot in the nut just into the thread then crush the nut to close the gap. this will act as a simmonds nut and prevent it from vibrating lose. Just be careful though as it will be weaker.
    Another one is when a tapped hole is cross threaded. Cut three slots in a slight spiral up a bolt (obviously the same thread) and carefully screw it in the hole. This acts as a tap and with luck it`ll clean the damaged thread up.
    As I said earlier these are get out of jail cards when youre in a fix.
  31. #31
    Sep 2008
    429
    Another one I remembered from my days on the railways working as an apprentice under the old steam boys. When opening a gate valve (or Rotolock valve), open it fully to its stop then turn it back half a turn. Anyone trying to open it later will Know it`s already open as it only turns half a turn. Many a time I`ve tried opening a valve suspecting it seized only to find someones wound it fully open.
    Also if it is seized that half a turn should be enough to free any crap behind it.
  32. #32
    amoureman's Avatar
    amoureman Guest
    Quote Originally Posted by superswill View Post
    Good idea bad idea?
    OVER TO YOU GUYS
    great idea some sercice tips and quick tricks to resolveing puzzling problems would be good too
