Thread: Cold Air Dryer
28-04-2008, 08:08 AM #1
Cold Air Dryer
Hi guys,
I need again your help and now about 'cold air dryer'.
As I know only the drying process by hot air and I just informed by someone's that the drying process could be done by cold air refrigeration system.
Any body can help me about the process and the product to be dried is small fish.
Thanks for your attention and kind help.
28-04-2008, 10:13 AM #2
28-04-2008, 10:14 AM #3
Re: Cold Air Dryer
:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d
28-04-2008, 03:32 PM #4
Re: Cold Air Dryer
Air can be dried if you drop it's temperature below the dew point, remove the condensate and reheat it again. Usually, the machine has two heat exchangers: a regenerator and a cooler. The first one reheats the outcoming air using some of the heat load of the inlet air. The second cools the air to the desired dew point, and can be a refrigeration evaporator or a chilled water/air HE. The condensate separation device can be a centrifugal or labirint separator or even a coalescing filter.
Good luck with your fishes!
29-04-2008, 06:03 AM #5
Re: Cold Air Dryer
Thanks a lot guys for your help.
cold river water
By eftimios in forum FundamentalsReplies: 8Last Post: 09-11-2008, 06:37 PM -
Porkka cold rooms
By Andy AC in forum CommercialReplies: 6Last Post: 29-08-2007, 08:14 AM -
expansion valve aint cold
By justinworne in forum Trouble ShootingReplies: 6Last Post: 26-07-2006, 10:52 PM -
Installation of cold room
By Josip in forum Legal-Business-MarketingReplies: 12Last Post: 12-03-2006, 09:20 PM -
Freezer not cold enough, Fridge too cold
By barrance in forum CommercialReplies: 4Last Post: 06-12-2001, 06:11 PM
