Thread: Cold Air Dryer
    Nov 2007
    Jakarta
    75
    11
    Cold Air Dryer
    Hi guys,
    I need again your help and now about 'cold air dryer'.
    As I know only the drying process by hot air and I just informed by someone's that the drying process could be done by cold air refrigeration system.
    Any body can help me about the process and the product to be dried is small fish.
    Thanks for your attention and kind help.
    Apr 2008
    philippines
    95
    Talking Re: Cold Air Dryer
    Quote Originally Posted by maguro4448 View Post
    Hi guys,
    I think you should put your fishes in the condensing units!!
    Apr 2008
    philippines
    95
    Re: Cold Air Dryer
    :d:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d:d
    Aug 2007
    Brazil
    44
    8
    Re: Cold Air Dryer
    Hi guys,
    Air can be dried if you drop it's temperature below the dew point, remove the condensate and reheat it again. Usually, the machine has two heat exchangers: a regenerator and a cooler. The first one reheats the outcoming air using some of the heat load of the inlet air. The second cools the air to the desired dew point, and can be a refrigeration evaporator or a chilled water/air HE. The condensate separation device can be a centrifugal or labirint separator or even a coalescing filter.
    Good luck with your fishes!
    Nov 2007
    Jakarta
    75
    11
    Re: Cold Air Dryer
    Thanks a lot guys for your help.
  1. cold river water
    By eftimios in forum Fundamentals
    Last Post: 09-11-2008, 06:37 PM
  2. Porkka cold rooms
    By Andy AC in forum Commercial
    Last Post: 29-08-2007, 08:14 AM
  3. expansion valve aint cold
    By justinworne in forum Trouble Shooting
    Last Post: 26-07-2006, 10:52 PM
  4. Installation of cold room
    By Josip in forum Legal-Business-Marketing
    Last Post: 12-03-2006, 09:20 PM
  5. Freezer not cold enough, Fridge too cold
    By barrance in forum Commercial
    Last Post: 06-12-2001, 06:11 PM
