Results 1 to 10 of 10
    mr whippy's Avatar
    mr whippy Guest
    Carpigiani ice cream machine charging
    hi have to gas a carpigiani ice cream machine fitted in an ice cream van,I no very little about this but can stick a drop of gas in to get it freezing again.
    It used to run on 502 but have been advised that 408 is the replacement gas? it has a sandon compressor which seems to squeal a lot when you be using it for a long time?
    any hints any one as ti what would make compressor squeal and how much gas to put in?
    I can get it to freeze back to compressor with out clearing the site glass but am wondering is ther not enough/to much gas in the system and would this make it squeal,many thanks for any info
    Nov 2005
    New Zealand
    550
    Re: Carpigiani ice cream machine charging
    hi Mr whippy stick to selling ice cream and get a professional to add the refrigerant
    Norm
    mr whippy's Avatar
    mr whippy Guest
    would do but no-body wants to look at ice cream vans and those that have haven`t a clue, was only asking a question,
    shaileshjoshi's Avatar
    shaileshjoshi Guest
    Hi to all
    How to find out heat transfer coefficient of Co2 liquifier?
    Please help me.....
    4,702
    Quote Originally Posted by mr whippy View Post
    Despite your obvious frustration, you will need to employ the services of a Fridge Engineer.
    Because if you have read these pages enough? You will be aware that unless you are suitably qualified.
    It is Illegal to work on refrigeration equipment.
    Also don't be surprised if you are subsequently advised that it is not just a case of re gassing.
    Possibly 10 yrs ago or more I changed a compressor on an ice cream van. (So called R49 Isceon "drop in".)
    Several recalls later I finally realised this "drop in" was fine when the system was ac with copper pipework.
    Fit it to a vehicle with the original flexible hoses and they leaked like a sieve.
    Sadly your system may of reached it's end and a new or system change may be required.
    Toosh is correct, unpalatable as it may be get a professional.
    ps it may pay to say where in the UK. You are as there are good self employed lads UK Wide that may choose to help?
    Mar 2008
    54
    273
    These machines operate on exact gas pressures so you will not be able to set it up correctly unless you are a expert. If compressor squeals then this is a compressor fault. Suction line should not be frozen back to compressor either.
    mr whippy's Avatar
    mr whippy Guest
    Thank you for your replys,Grizzly understand what your saying ref flexi hoses as once bought one and had to strip the lot out and replace as you say, just outta interest i`m based in belfast and no-one works on them over here thanks again
    Nov 2005
    New Zealand
    550
    Quote Originally Posted by shaileshjoshi View Post
    Hi to all
    Please help me.....
    Have you tried Google its a wonderfull tool to locate things.
    and I don`t think this thread is the place to ask
    Norm
    3,856
    Hi Mr whippy,
    What about someone who does refrigerated trucks or Car air con rather than companies that do fixed systems?
    Jon
    Mar 2006
    belfast
    239
    plenty of people will look at it for u... its maybe the price u wont like
  1. carpigiani ice cream machine temp settings
    By superwhippy in forum Trouble Shooting
    Last Post: 04-05-2010, 08:23 PM
  2. Charging soft serve ice cream machine
    By terrygoodrich in forum Commercial
    Last Post: 03-03-2010, 01:43 PM
  3. ice cream machine
    By jnyao in forum Commercial
    Last Post: 08-07-2007, 09:15 PM
  4. Elderly Ice cream machine.
    By Onthecut in forum Trouble Shooting
    Last Post: 20-11-2005, 11:31 AM
  5. Cattabriga Ice Cream Machine
    By Abe in forum Trouble Shooting
    Last Post: 26-04-2003, 01:06 PM
