Results 1 to 1 of 1
30-04-2008, 05:37 AM #1
Whirpool 1992, 20ft3 fridge runs/no cold.
It's an older model, runs on R134A but I want to learn on that thing.
Compressor takes 6.5 amps at the start as stated on the sticker. Then it goes down to 0.6amps and I found on the web it should be 0.99amps. Very little cooling afect on the tubing in the freezer.
Hi side pressure 110psi and should be at 90F temperature (I have it outside) 145+-20psi.
I sniffed around for leaks, soaped it and nothing.
No condensor fan on this unit, no frost developing anywhere so I am puzzled and would be happy to get some hint, Thanks.
fridge warm freezer cold?
By babsnsarah in forum DomesticReplies: 25Last Post: 30-04-2011, 04:24 PM -
Hoover Optima - Freezer warm, fridge cold
By aberchick in forum DomesticReplies: 3Last Post: 08-05-2008, 09:45 PM -
Beko Fridge Freezer Bubbles & Does Not Get Cold!!!!
By scoobey in forum DomesticReplies: 11Last Post: 16-03-2008, 07:12 PM -
Zanussi - fridge is warm but freezer is cold.
By Bob Ball in forum Trouble ShootingReplies: 2Last Post: 11-02-2007, 04:59 PM -
Freezer not cold enough, Fridge too cold
By barrance in forum CommercialReplies: 4Last Post: 06-12-2001, 06:11 PM
