Results 1 to 13 of 13
Thread: Mitsi HI controller
24-04-2008, 11:54 AM #1
Mitsi HI controller
Hello everybody
Has anyone got a copy of the technical manual for the MHI RC-E-1 contoller. Would really appreciate it
24-04-2008, 02:42 PM #2
Re: Mitsi HI controller
Did a quick look in the US site for that controller, nothing. It appears that it is one sold in England. I suggest you call Mitsubishi Tech at: Telephone: 0870 3000 300. They may be able to e-mail you a pdf file.
I can't paste the website for Mitsubishi Electric UK, but a google search will get you there. Maybe this will work.
Cut and paste in the address line of your browser.
mitsubishi-aircon.co.uk
Good Luck
24-04-2008, 04:49 PM #3
sorry saillar
I may have misled you its not a mitsubushi electric the HI is for Heavy Industries. Thanks all the same for having a look for me I couldnt get through to them and I bet when I do they`ll offer to send a CD rom out next day that I might receive next blue moon.
24-04-2008, 07:45 PM #4
I think I've got a copy filed away somewhere...
What's the problem? Direct question since I w'ont be able to scan you a copy.
Saludos
24-04-2008, 08:28 PM #5
Hiya mate,
Ive sent you an email, hope it helps. I've still not figured out how to attach a copy to this site, computers are not my thing.
Regards, Andy C.
25-04-2008, 09:42 AM #6
Saludos
No problem as such just want to know how much you can do with it plus the filter timer is getting to be a pain in the a**e.
25-04-2008, 09:55 AM #7
Hi. If memory serves the Filter Timer on this hard wired controller can be set as follows:-
- No display
- 180hrs
- 600hrs
- 1000hrs
- 1000hrs - stop unit
Clever controllers these but not the easiest to navigate. Hope this helps.
26-04-2008, 10:36 AM #8
Can any of you guys tell me if there is any way of checking indoor sensor readings from the control like Daikin?
28-04-2008, 09:51 PM #9
Hi Puddleboy3 This is copied out of the manual for the Mitsi R410 manual. Hope it helps,, The numbers down the bottom correspond the the items below it,
(4) Checking Operation Data Operation.
data can be checked using the remote controller.
1,Press the CHECK button.
The display will change from “ SELECT ITEM” “ SET"
“OPERATION DATA .”
2 When “OPERATION DATA ” is displayed, pres the SET button.
3 The display changes to “I/U No. 00 ” (flashing).
Using the up or down button, select the number of the indoor unit you want to
display.
(When there is only one indoor unit connected, the indoor unit No. does not
change.)
4 Fix the No. by pressing the SET button.
(The indoor unit No. changes from flashing to lighted up continuously.)
The message “DATA LOADING” is displayed flashing while data are being
read.
“OPERATION DATA ” and data No. 01 are displayed.
5 Display the other data in order from the currently displayed operation data No.
01 by using the up or down button.
The items displayed are as shown at right.
Note (1) Depending on the model, items for which corresponding data do not exist are not displayed.
6 To change the indoor unit, press the AIR CON No. button and return to the
indoor unit selection display.
7 Press the ON/OFF button to end the data check.
Number
01
02
03
04
05
07
11
21
22
23
26
27
28
29
31
32
33
34
35
36
37
38
Operation mode
Temperature setting
Intake temperature
Indoor heat exchanger temperature 1
Indoor heat exchanger temperature 2
Indoor fan speed
Indoor unit operation hours
Outside air temperature
Outdoor heat exchanger temperature 1
Outdoor heat exchanger temperature 2
Operation Hz
Low pressure
Discharge pipe temperature
Temperature beneath the dome
CT current
Outdoor fan speed
Silent mode enabled/disabled
63H2 ON/OFF
63H1 ON/OFF
Defrost ON/OFF
Compressor operation hours
Expansion valve opening 1
Expansion valve opening 2
DATA ITEM
If the RESET button is pressed during the setting operation,
the screen returns to the previous setting screen.
29-04-2008, 11:16 PM #10
Thanks Stuart, have you worked on any of the MHI systems. We have just completed a installation of a few split systems. I was suprised at the good quality of the units.
30-04-2008, 10:18 PM #11
Hi. The only heavy ind kit i have worked on is older pre installed stuff. My company don,t install it but i do like working on it.For being a cheaper kit its pretty good.
14-05-2008, 05:37 PM #12
Please find attached details requested
14-05-2008, 05:39 PM #13
Daikin Hard wired controller
By marc5180 in forum Air ConditioningReplies: 16Last Post: 10-11-2007, 06:43 PM -
H0 on Mitsubishi Controller
By Freecool in forum Air ConditioningReplies: 2Last Post: 29-09-2007, 07:24 PM -
Help with new electronic refrigerator controller !
By EngiGal in forum New TechnologiesReplies: 17Last Post: 08-04-2006, 07:39 PM -
Controller wiring
By Mickvee in forum Air ConditioningReplies: 2Last Post: 30-12-2005, 02:04 AM -
Fan Controller
By Abe in forum Trouble ShootingReplies: 4Last Post: 12-01-2002, 02:21 AM
