Thread: York Twins
20-04-2008, 11:37 PM #1
York Twins
Hi Everyone!
I´m Looking For Some Help Regarding A Burn Out Compresor In A Package Ac(york 25 Tons), I´m Suggesting Changing Both Compressor But Some Genious Up There(boss) Suggested Changing Just One, Can I Get Some Help To Talk This Genious Out Of His Idea, Thanks.
P.s. Or If I´m Wrong, Please Correct Me
21-04-2008, 03:54 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: York Twins
And, what is your argument for changing both?
22-04-2008, 09:23 PM #3
Re: York Twins
If both compressors are on the same system (ie share a common suction and discharge)then yes you would definately change both comps as the other motor could be damaged.
22-04-2008, 10:57 PM #4
Re: York Twins
Even if you change both compressors at the same time, they could also fail if the system is not properly cleaned up.
Spend the time and money to change one compressor and do a very good job of cleaning the system and installing new acid core driers and changing the oil in the remaining old compressor.If all else fails, ask for help.
YORK ducted split
By ALONEI in forum Trouble ShootingReplies: 7Last Post: 10-07-2010, 02:18 AM -
York Screw Oil Problem
By tomt in forum Technical DiscussionsReplies: 10Last Post: 02-12-2009, 02:48 PM -
York Screw Chiller How low will it go?????
By bruceboldy in forum Industrial CompressorsReplies: 11Last Post: 10-08-2007, 10:29 PM -
York Reciprocating Compressor
By lldelfin67 in forum Industrial CompressorsReplies: 0Last Post: 17-07-2007, 03:56 PM -
York process chiller repairs
By Matt in forum CommercialReplies: 5Last Post: 23-03-2004, 11:07 PM
