Thread: Suction accumulators
20-04-2008, 02:57 PM #1
Hello
I read somewhere that suction accumulators can be useful in plated heat exchanger systems since with these plates the liquid refrigerant tends to condesate when the compressor is off.
Why liquid receiver tends to condensate when compressor is off? can anyone explain?
thanks
20-04-2008, 06:38 PM #2
Re: Suction accumulators
What actually happens on some systems (without a solenoid valve in the liquid line and pump down to stop) is that the plate heat-exchanger used as evaporator fills up with liquid as it's the coldest part of the circuit. When the compressor then starts, it will try and compress liquid refrigerant...
A suction accumulator will reduce the risk of liquid reaching the compressor (so would a proper pumpdown)
20-04-2008, 10:40 PM #3
To answer your second question; with out a soleniod valvle for pump down. The refrigerant will continue to migrate to the coldest prt of the system (cold plates).
When the level lquid level in the receiver drops below the king valve intake the refrigerant starts to boil and absorb heat. Thus dropping the tank below dewpoint and condensating where liquid touches the sides.
21-04-2008, 04:20 PM #4
Thanks a lot to both
22-04-2008, 07:20 AM #5
What's King Valve?
22-04-2008, 07:42 AM #6
The shutoff service valve on the receiver outlet
22-04-2008, 02:56 PM #7
Originally Posted by Peter_1
I have never heard an explanation of how this valve came to be named this though?If all else fails, ask for help.
Copeland select 6
By Copman in forum Tools and CalculatorsReplies: 9Last Post: 27-05-2010, 09:01 PM -
Some information on the aplication of suction gas/liquid line heat exchangers
By SteinarN in forum FundamentalsReplies: 5Last Post: 14-09-2009, 07:33 AM -
Should suction accumulators be insulated?
By superheated in forum CommercialReplies: 7Last Post: 16-02-2008, 07:12 PM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
Suction Accumulators
By rsiyer in forum Technical SpeculationsReplies: 2Last Post: 15-06-2007, 04:16 AM
