Results 1 to 19 of 19
Thread: Digital scroll
    Apr 2008
    Germany
    55
    10
    Digital scroll
    I'm new in this forum and in this field/market
    has anyone heard about Copeland digital scroll and its performance in hydronic systems (chillers / heat pumps)?
    any idea on how to control it? how would you drive the EXV given the pulsating nature of the compressor?
    thanks fo your help
    Split Croatia
    57
    6,151
    36
    Re: Digital scroll
    Try to find something from this manual:
    http://tinyurl.com/65v5xh
    Apr 2008
    Germany
    55
    10
    Re: Digital scroll
    Thanks a lot nike123
    this is a manual for a VRF system, multievaporators, very interesting
    any idea if there is something available also for hydronic, single evaporator systems?
    Apr 2008
    Germany
    55
    10
    Re: Digital scroll
    Jan 2008
    India
    70
    171
    Re: Digital scroll
    Is it possible to control temperarure and Relative Humidity with only Electronic Expansion Valve.If it is possible, kindly explain how it is achieved.
    Jun 2008
    Las Vegas
    64
    11
    Re: Digital scroll
    TO Control RH you lower the capacity to increase run time while keeping the evap under dew point. To Raise RH (provided you have enough moisture input to begin with an empty cooler with no aspirating media would not work or you add humidifier) You Raise Capacity over that neassassary to cool the space to shorten the run time thereby cooling in the shortest possiable time removing as little as possiable moisture.
    IN Meat curing roms we use Freezer coils Wide range TXV's and small misters. the Misters are set at the min Humidity nessassary the heaters are set at the maximum Humdity, and system capacity is designed by load calcs plus 10%, this system is very energy unconscious but it is simple. The electronic TXV would be the best but still would need some form of humidification occationally.
    GXMPLX's Avatar
    GXMPLX is offline Veteran Poster I am starting to push the Mods: of RE
    May 2008
    weston
    348
    Re: Digital scroll
    Quote Originally Posted by Sridhar1312 View Post
    No, you can not. As Chilly1 says, the only possibility is to lower it until you reach a point above the coils dew point at the set temperature. But the final air water content will depend on other conditions (moisture given off by the product, infiltration conditions, etc)! Only if you have no added moisture you could know final relative humidity. With normal TXVs you cannot do even this but you are not controlling it in the way I understand "controll".
    Oct 2003
    5,630
    34
    Re: Digital scroll
    Quote Originally Posted by Camalla View Post
    thanks fo your help
    Together with the compressor, they deliver also the proper controller for the valve.
    You don't have pulsations with a scroll and you even don't see pulsations with the digital scroll while throttled. The pulsations are flattened out in the evaporator and condenser.
    If you should see pulsations, the you should see those also with the EEV's from Danfoss (AKV's puls/pause principle)
    Nov 2005
    211
    Re: Digital scroll
    With just an electronic expansion valve, no. But it is part of a system that allows precise temperature and humidity control.
    Basic idea is to modulate system capacity (compressor speed and expansion valve restriction) to regulate amount of cooling and air handler fan speed to optimize the system for dehumidification or cooling. Since A/C systems are more efficient at part load, a smart controller can try to run the compressor at low speeds when possible. The air handler fan runs at lower speeds in relation to compressor capacity for more effective dehumidification.
    "If Hannah was an air handler, I would be a condensing unit so I could open her TXV and pump my refrigerant through her coils." - a HVAC friend of mine
    urajat's Avatar
    urajat Guest
    Re: Digital scroll
    I know one manufacturer blue star they manufacture VRF system with digital scroll. Humidity is controlled by controlling dt of evaporater and heaters. for humidification humidifier is used.
    Nov 2008
    Thailand
    5
    Re: Digital scroll
    I heard that, in VRF system, digital scroll is better than inverter in term of dehumidification because of....(I am not quite clear)... Can someone explain in details why?
    Apr 2004
    Pakistan
    44
    129
    21
    Re: Digital scroll
    We have installed many digital scroll systems and yes it is way better than inverter system in all respects.
    Digital scroll capacity modulation is from 10% to 100% with respective power consumption of 10%-100% also it has very less rather none electronic components compared to inverter system. Inverter cannot run below 40% compared to 10% of digital compressor system. EER of digital scroll is way higher than best japanese inverter in market.
    I have whole presentation in this regard. I can email you if you want. Also click link below
    http://www.digitalscroll.com
    Our nose is our personal air-conditioning system: it warms cold air, cools hot air and filters impurities
    Apr 2004
    Pakistan
    44
    129
    21
    Re: Digital scroll
    Quote Originally Posted by thmech View Post
    It has low sensible heat ratio (LSHR)that is sole reason of better dehumidification +-2%
    Nov 2008
    Thailand
    5
    Re: Digital scroll
    [/quote]
    Quote Originally Posted by abbasi View Post
    I am so busy for while, by the way thank you.
    [quote=abbasi;126939]We have installed many digital scroll systems and yes it is way better than inverter system in all respects.
    Yes, I am interesting in that presentation so can you mail it to me at kobj03 yahoo mail.
    Oct 2008
    philippines
    36
    Re: Digital scroll
    Sound good. What application have you used the Digital Scroll system with? What OEMs did you use?
    Mar 2007
    Warwickshire UK
    723
    21
    Re: Digital scroll
    You need to check out the facts yourself.
    From personal experiance & technical manuals to hand i find that the information in the Emerson presentation to be highly misleading. Ofcourse any manufacturer will try to spin information to make there product look like the best product available.
    But the claims about poor performance of VRF systems are completely overstated & mileading when checked against technical data for leading VRF manufacturers.
    If any critical investigation of all digital scroll manufacturers was undertaken & one negative point taken from each & then the accumulation of all those negative points compared to the best VRF system, then the presentation would clearly show that VRF is much better than DS.
    When viewing any manufacturers presentation about the features & advantages of that product you do need to be able to see past the smoke screen & spin & mis information.
    You very often will find the advantages of the product overstated & the disadvantages of the competition overstated & the benifits of the competion not mentioned at all.
    Oct 2008
    philippines
    36
    Re: Digital scroll
    It is interesting to find VRF systems being applied where traditional A/C systems have been commonly used in the past. High rise buildings, commercial complex with huge spaces now use VRF systems specially in Asia.
    Split Croatia
    57
    6,151
    36
    Re: Digital scroll
    Quote Originally Posted by mekaniko5 View Post
    That doesn't mean that VRF is technically better solution than Digital Scroll or water chiller systems.
    Compare that with VHS and BETA video system.
    Beta is much more advanced but VHS is commercially cheaper and simpler to produce. Availability wins over technical excellence when customers are wiling to tolerate that.
  19. #19
    Oct 2008
    philippines
    36
    Re: Digital scroll
    Digital Scroll Compressors are actually being used for VRF System.
    The main difference from other modulated capacity system more commonly named as VRVs is that the motor runs at a fixed speed rather that variable speeds.
  1. vrv vs digital scroll
    By katyalrk in forum Technical Discussions
    Last Post: 16-11-2010, 08:03 PM
  2. copeland digital scroll tech
    By Lc_shi in forum Air Conditioning
    Last Post: 27-05-2009, 12:24 AM
  3. use of digital scroll technology
    Last Post: 11-11-2008, 02:12 PM
  4. Digital Scroll Technology
    By Dan in forum New Technologies
    Last Post: 17-06-2008, 08:02 PM
