Results 1 to 14 of 14
    U.A.E
    42
    12
    Oxy Acytelene Welding
    Hello Guys,
    I have a question concerning the selection of the oxy acytelene kit
    I am using the above procedure for welding Copper pipes Type L according to ASTMB88-96 my problem is that I don't know which weding tip size should I select as my copper pipe diameter is 21/8'' and how should I select the tip.
    could i use a double tip or one is enough?
    If any body can provide me with a guide for the tip selection or even give me the selection or a supplier or anything concerning this issue I would be very grateful.
    Thank you in advance and best regards
    Jan 2008
    Kent UK
    49
    514
    Re: Oxy Acytelene Welding
    If it ain't broke, it doesn't have enough features yet.
    Damo
    Jan 2008
    Manchester, Uk
    Hi Hipposs,
    I used to find using a size 18 nozzle worked for me on 2.1/8" tube, but then I only had four sizes, No.3 for small stuff, No.7 for medium, No.13 for big, and No.18 for bigger sizes. It worked for me, but I haven't done upward of 2.1/8" for a few years and cant remember what size nozzle I used for 4.1/8". I'm sure someone else will be able to shed some light.
    Regards, Andy C.
    Feb 2007
    2,473
    For those pipe sizes you will nee the largest nozzle you can find.
    Personally, I favour THIS type, commonly known as "shower-heads". The have 7 or more orifices built in to the tip, giving lots of heat over a wide area.
    Jan 2008
    Kent UK
    49
    514
    Pepperpots.
    Damo
    Feb 2007
    2,473
    "A loved child have many names"
    (Chinese proverb)
    Jan 2008
    Kent UK
    49
    514
    That link i posted up top,is that chart any good?
    Damo
    Aug 2005
    5,302
    I have used tips similar to those described by The Viking. Thed do cover a large area with a large flame, but you still have to move the tip around to evenly heat larger pipes. And be careful with the oxygen settings. You do not want a cutting torch!
    My best advice is to heat the pipe uniformly all the way to the depth of the fitting socket and not get in a big hurry. Large pipes take time to braze well.
    Split Croatia
    6,151
    I dont know there, but here I have nozzles marked
    0,5-1
    1-2
    2-4
    6-9
    9-14
    14-20
    and I using 6-9 and 9-14 for 54mm CU pipes.
    3,853
    Since getting a pepperpot burner i've used nothing else (except a mapp gas blow lamp on small stuff) Every oxyacc set should have one, great for compressor changes etc.
    Years ago i did some 3 1/8 pipe but for that we just drilled out a nozzle to get a bigger flame....don't try this!
    Last edited by monkey spanners; 15-04-2008 at 11:41 PM. Reason: smilies etc gone w*nky
    Oct 2003
    5,630
    Or this ones at the bottom of the pages http://www.mir.be/NL/catalogue.php?cid=11
    Feb 2008
    Norway
    446
    I find it preferable to use this type of nozzle from 1 1/8" inch and upwards. It heats more "softly" and over a wider area. It gets faster to heat the large pipes with that "multi nozzle" burner.
    U.A.E
    42
    12
    thanks guys your posts have been of a great help for me
    Feb 2008
    502
    Citb Brazing Recomend Pepperpots
  1. Suction Line Welding
    By Brian G in forum Fundamentals
    Last Post: 14-05-2007, 07:41 AM
  2. Bad welding... hate it
    By Tycho in forum Chit Chat & Service Stories
    Last Post: 28-02-2007, 10:27 PM
  3. welding copper pipes
    By kpapa in forum Tools and Calculators
    Last Post: 25-09-2006, 10:12 PM
  4. welding copper
    By kpapa in forum Trouble Shooting
    Last Post: 02-09-2006, 09:55 AM
